CS6
If you have question about Neutralhazer plugin for Photoshop, this is the right place.
leifs
CS6
by leifs » Fri Jul 26, 2013 2:02 pm
I just bought NH and had a nasty surprise: it does not work with CS6 (?)
CS6 was released may 2012 and I took it for granted NH now supported it.
After I bought it I got this link in the readme-file:
http://www.kolor.com/neutralhazer-haze-remover-photo-photoshop-plugin-faq.html
Her it stops at CS5.
Questions to Kolor:
when will there be a version working on CS6 ??
leif
Seitz VRdrive2
leifs
by leifs » Sat Jul 27, 2013 7:00 pm
after some fiddling I got NH to work on CS6.
only to experience an disappointment:
I loaded a finished 360 cylinder and thought it would benefit from some haze removed.
as shown below NH does not coordinate the haze removal on the right/left edge.
Back to square one.
leifs
Seitz VRdrive2
ygilquin
by ygilquin » Mon Jul 29, 2013 8:48 am
Neutralhazer algorithm does not support spherical or cylindrical warping. It's a known missing feature we target for next version.
Yann G.
www.kolor.com
Likes: 3 posts
Liked in: 225 posts
by Destiny » Mon Jul 29, 2013 9:05 am
.... an option is to use OffSet and BlendLayers Tools in Photoshop... Fix it quick an easily....
leifs
by leifs » Mon Jul 29, 2013 10:31 am
for this small pano (12 images) I took it from square one:
http://www.rundskuer.no/panotour/skardstind/virtualtour.html
I would like to revisit some spheres and then it would be nice to remove the haze on the stitched image, instead of redo everything.
leifs
Seitz VRdrive2
