NH with XNVIEW MP : need to re-register
If you have question about Neutralhazer plugin for Photoshop, this is the right place.
panoed92
by panoed92 » Sat Oct 06, 2012 6:25 pm
I manually installed /kolor/neutralhazer in C:/Psplugin where I usually put the 8bf plugins used by xnviewmp.
Each time I want tu use the plugin, I must re-register to avoid the "KOLOR" watermark.
Can you provide a solution to permanently register NH?
As results are awesome, I am impatient to solve the issue.
André
ygilquin
by ygilquin » Tue Oct 09, 2012 10:18 am
Dear André, I guess you're running a too old version of XnView. The problem you report is solved since version 1.99. I suggest you should get and install the last version.
http://www.xnview.com/en/download.html
Yann G.
www.kolor.com
panoed92
by panoed92 » Thu Oct 11, 2012 8:21 am
I was running the xnview MP 0.51 which is a new version which can also be used on unix and mac.
P.E. Gougelet answered on the xnview forum that he will correct this registration issue.
Registration works with xnview 1.99.1
Thank you
André
jsjamesok
by jsjamesok » Mon Nov 19, 2012 12:07 pm
How do I get the plug in to appear in XNView? I can't seem to figure that out.
ygilquin
by ygilquin » Mon Nov 19, 2012 1:04 pm
Once you have opened your image in XnView, open menu "filter > Adobe Photoshop Plug-In". This will open a dialog window allowing you to set paths to your installed PS plug-ins.
Yann G.
www.kolor.com
