Not enough Ram
If you have question about Neutralhazer plugin for Photoshop, this is the right place.
jl-kol
Not enough Ram
by jl-kol » Mon Apr 30, 2012 10:53 am
Neutralhazer works very well but fails at large file sizes e.g.19000 x 9500 x300 16b
'Not enough Ram' message though my Mac Pro has 32GB.
The size limit seems to be about 18500 x 9250 & the D800e produces 19652 x 9826
Any chance of increasing the ram limit?
JL
by klausesser » Mon Apr 30, 2012 11:44 am
jl-kol wrote:Neutralhazer works very well but fails at large file sizes e.g.19000 x 9500 x300 16b
JL
Hi!
You´d better use the NH on the single shots before stitching instead afterwards on the whole panorama-image . . ;):cool:
The size of an image coming from a D800n is 7,360 x 4,912px afaik.
jl-kol
by jl-kol » Mon Apr 30, 2012 1:55 pm
Hi Klaus
Interesting suggestion to process first then stitch but it doesn't work as well as reducing the image size to below 18500 and precessing the whole image.
I still think raising the RAM bar is a better solution!
Two jpg fragments are attached 'all together' & 'separate'
Regards
JL
ygilquin
by ygilquin » Mon Apr 30, 2012 4:05 pm
You can process big images, but for big images, we recommend using 64-bit versions of Photoshop. What version of Photoshop are you using ?
Yann G.
www.kolor.com
jl-kol
by jl-kol » Mon Apr 30, 2012 4:11 pm
Hello Yann
64 b CS5 on a mac pro with 32gb ram
JL
ygilquin
by ygilquin » Mon Apr 30, 2012 4:24 pm
You can submit us your image for check purpose, following instructions available at http://www.kolor.com/forum/t766-ftp-server
Yann G.
www.kolor.com
jl-kol
by jl-kol » Mon Apr 30, 2012 5:40 pm
Thanks Yann a large zipped file is ftp-ing to you now.
JL
tived
by tived » Tue May 01, 2012 9:13 am
I'll give it a spin when I get back on thursday, and see what the limit is for 96gb of ram
Henrik
jl-kol
by jl-kol » Tue May 01, 2012 2:35 pm
Thanks Henrik
There is probably a software limit in NH as my images open easily in pShop, so you could open a dozen huge images with your setup!
What is the largest you have made?
JL
gavinfarrell
by gavinfarrell » Mon Sep 10, 2012 6:12 am
Hey jl-kol I am desperate to get this filter to work on my large gigapixel Images which range from 1.6 to 30 GIG files. I found that if I save the .PSB file to a Photoshop RAW (.raw) I able to at least get as far as them opening up in the filter window. However as soon as I try to apply the filter Photoshop completely crashes with a memory error. My question to you is have you upgraded to Photoshop CS6 ? That's what I am using. And secondly can you pleas try saving you file as a Photoshop .RAW file? For it to work you need to include the width and height in you filename when you save it out. For instance: MyPicture_136671_24896.raw The reason I'm asking is that I only have 16GB of RAM and I'm trying to ascertain if having 32GB of RAM, as you do, will help get this filter to work. I hope you try combining my file technique with your system and let me know if you have any success. Thanks!
Tanate
Re: Not enough Ram
by Tanate » Thu Nov 21, 2013 11:30 pm
I do have the same problem with Photoshop 6 (64bit) when ever I open the neutralhazer photoshop will crash.
Liked in: 227 posts
Re:
by Destiny » Fri Nov 22, 2013 12:21 am
I personally feel thats its really nice of Kolor to ask for the images to test, and equally nice that the photographer accepts the offer and sends the images..
What I don't feel is so great; We rarely hear again from Kolor after or see any results of their test.. Since this issue has been posted on a public forum, I feel it would be nice for other forum users to be apprised of the results from Kolor..
ygilquin wrote:You can submit us your image for check purpose, following instructions available at http://www.kolor.com/forum/t766-ftp-server
leifs
Re: Re:
by leifs » Fri Nov 22, 2013 9:45 am
Destiny wrote:What I don't feel is so great; We rarely hear again from Kolor after or see any results of their test..
I agree !
I've uploaded some images and it felt like uploading them into a black hole.
No response to me and no response for other readers either.
leifs
