Dedicated Tmelapse application
by klausesser » Mon Mar 15, 2010 6:06 pm
olihar wrote:Here is the motion curve from it made in Nuke.
First time i see Nuke used for that . . . :cool:;)
claudevh
by claudevh » Mon Mar 15, 2010 6:16 pm
OK Frederic, I will try ....:/
You already have all the low-level parts (just use the code from Papywizard; I can provide a version without any dependencies to Papywizard)
Could-you provide this "version" to me ?:rolleyes:
:cool: Claude :cool:
by fma38 » Mon Mar 15, 2010 6:50 pm
Here it is:
# -*- coding: utf-8 -*-
""" Panohead remote control.
License
 - B{Papywizard} (U{http://www.papywizard.org}) is Copyright:
  - (C) 2007-2010 Frédéric Mantegazza
This software is governed by the B{CeCILL} license under French law and
abiding by the rules of distribution of free software.  You can  use,
modify and/or redistribute the software under the terms of the CeCILL
license as circulated by CEA, CNRS and INRIA at the following URL
U{http://www.cecill.info}.
As a counterpart to the access to the source code and  rights to copy,
modify and redistribute granted by the license, users are provided only
with a limited warranty  and the software's author,  the holder of the
economic rights,  and the successive licensors  have only  limited
liability.
In this respect, the user's attention is drawn to the risks associated
with loading,  using,  modifying and/or developing or reproducing the
software by the user in light of its specific status of free software,
that may mean  that it is complicated to manipulate,  and  that  also
therefore means  that it is reserved for developers  and  experienced
professionals having in-depth computer knowledge. Users are therefore
encouraged to load and test the software's suitability as regards their
requirements in conditions enabling the security of their systems and/or
data to be ensured and,  more generally, to use and operate it in the
same conditions as regards security.
The fact that you are presently reading this means that you have had
knowledge of the CeCILL license and that you accept its terms.
Module purpose
Hardware
Implements
 - HardwareError
 - BluetoothDriver
 - MerlinOrionHardware
@author: Frédéric Mantegazza
@copyright: (C) 2007-2010 Frédéric Mantegazza
@license: CeCILL
__revision__ = "0.2"
import time
import bluetooth
ENCODER_ZERO = 0x800000
BT_ADDRESS = "00:50:C2:58:56:6B"
TIMEOUT = 1.
CONNECT_DELAY = 8.
YAW_AXIS = 1
PITCH_AXIS = 2
SHUTTER_AXIS = 1
class HardwareError(Exception):
    pass
class BluetoothDriver(object):
    """ Driver for bluetooth connection.
    def __init__(self, address=BT_ADDRESS):
        """ Init the bluetooth driver object.
        super(BluetoothDriver, self).__init__()
        print "BluetoothDriver._init(): trying to connect to %s..." % address
        try:
            self.__sock = bluetooth.BluetoothSocket(bluetooth.RFCOMM)
            self.__sock.connect((address, 1))
            try:
                self.__sock.settimeout(TIMEOUT)
            except NotImplementedError:
                print "BluetoothDriver._init(): bluetooth stack does not implment settimeout()"
        except bluetooth.BluetoothError, error:
            err, msg = eval(error.message)
            raise HardwareError(msg)
        else:
            time.sleep(CONNECT_DELAY)
            print "BluetoothDriver._init(): successfully connected to %s" % address
    def shutdown(self):
        self.__sock.close()
    def write(self, data):
        #print "BluetoothDriver.write(): data=%s" % repr(data)
        size = self.__sock.send(data)
        return size
    def read(self, size):
        data = self.__sock.recv(size)
        #print "BluetoothDriver.read(): data=%s" % repr(data)
        if size and not data:
            raise IOError("Timeout while reading on bluetooth bus (size=%d, data=%s)" % (size, repr(data)))
        else:
            return data
class MerlinOrionHardware(object):
    """ Merlin/Orion low-level hardware.
    def __init__(self, axis, driver):
        """ Init the MerlinOrionHardware object.
        super(MerlinOrionHardware, self).__init__()
        self.__axis = axis
        self.__driver = driver
        self.__encoderFullCircle = None
    def __decodeAxisValue(self, strValue):
        """ Decode value from axis.
        Values (position, speed...) returned by axis are
        32bits-encoded strings, low byte first.
        @param strValue: value returned by axis
        @type strValue: str
        @return: value
        @rtype: int
        value = 0
        for i in xrange(3):
            value += eval("0x%s" % strValue[i*2:i*2+2]) * 2 ** (i * 8)
        return value
    def __encodeAxisValue(self, value):
        """ Encode value for axis.
        Values (position, speed...) to send to axis must be
        @param value: value
        @type value: int
        @return: value to send to axis
        @rtype: str
        strHexValue = "000000%s" % hex(value)[2:]
        strValue = strHexValue[-2:] + strHexValue[-4:-2] + strHexValue[-6:-4]
        return strValue.upper()
    def __encoderToAngle(self, codPos):
        """ Convert encoder value to degres.
        @param codPos: encoder position
        @type codPos: int
        @return: position, in °
        @rtype: float
        return (codPos - ENCODER_ZERO) * 360. / self.__encoderFullCircle
    def __angleToEncoder(self, pos):
        """ Convert degres to encoder value.
        @param pos: position, in °
        @type pos: float
        @return: encoder position
        @rtype: int
        return int(pos * self.__encoderFullCircle / 360. + ENCODER_ZERO)
    def __sendCmd(self, cmd, param=""):
        """ Send a command to the axis.
        @param cmd: command to send
        @type cmd: str
        @return: answer
        @rtype: str
        cmd = "%s%d%s" % (cmd, self.__axis, param)
        #print "MerlinOrionHardware.__sendCmd(): axis %d cmd=%s" % (self.__axis, repr(cmd))
        for nbTry in range(3):
            try:
                answer = ""
                self.__driver.write(":%s\r" % cmd)
                c = ''
                while c not in ('=', '!'):
                    c = self.__driver.read(1)
                    #Lprint "MerlinOrionHardware.__sendCmd(): c=%s" % repr(c)
                if c == '!':
                    c = self.__driver.read(1) # Get error code
                    raise IOError("Error in command %s (err=%s)" % (repr(cmd), c))
                answer = ""
                while True:
                    #print "MerlinOrionHardware.__sendCmd(): c=%s" % repr(c)
                    if c == '\r':
                        break
                    answer += c
            except IOError:
                 print "MerlinOrionHardware.__sendCmd(): axis %d can't sent command %s. Retrying..." % (self.__axis, repr(cmd))
            else:
                break
        else:
            raise HardwareError("axis %d can't send command %s" % (self.__axis, repr(cmd)))
        #print "MerlinOrionHardware.__sendCmd(): axis %d ans=%s" % (self.__axis, repr(answer))
        return answer
    def init(self):
        """ Init the MerlinOrion hardware.
        Done only once per axis.
        # Stop motor
        self.__sendCmd("L")
        # Check motor?
        self.__sendCmd("F")
        # Get firmeware version
        value = self.__sendCmd("e")
        print "MerlinOrionHardware.init(): firmeware version=%s" % value
        # Get encoder full circle
        value = self.__sendCmd("a")
        self.__encoderFullCircle = self.__decodeAxisValue(value)
        print "MerlinOrionHardware.init(): encoder full circle=%s" % hex(self.__encoderFullCircle)
        # Get sidereal rate
        value = self.__sendCmd("D")
        print "MerlinOrionHardware.init(): sidereal rate=%s" % hex(self.__decodeAxisValue(value))
    def read(self):
        """ Read the axis position.
        @return: axis position, in °
        @rtype: float
        value = self.__sendCmd("j")
        self.__driver.releaseBus()
        pos = self.__encoderToAngle(self.__decodeAxisValue(value))
        return pos
    def drive(self, pos):
        """ Drive the axis.
        @param pos: position to reach, in °
        @type pos: float
        strValue = self.__encodeAxisValue(self.__angleToEncoder(pos))
        self.__sendCmd("L")
        self.__sendCmd("G", "00")
        self.__sendCmd("S", strValue)
        self.__sendCmd("J")
    def stop(self):
        """ Stop the axis.
        self.__sendCmd("L")
    def startJog(self, dir_, speed):
        """ Start the axis.
        @param dir_: direction ('+', '-')
        @type dir_: str
        @param speed: speed
        @type speed: int
        self.__sendCmd("L")
        if dir_ == '+':
            self.__sendCmd("G", "30")
        elif dir_ == '-':
            self.__sendCmd("G", "31")
        else:
            raise ValueError("Axis %d dir. must be in ('+', '-')" % self.__axis)
        self.__sendCmd("I", self.__encodeAxisValue(speed))
        self.__sendCmd("J")
    def getStatus(self):
        """ Get axis status.
        @return: axis status
        @rtype: str
        return self.__sendCmd("f")
    def setOutput(self, state):
        """ Set output state.
        @param state: new state of the the output
        @type state: bool
        self.__sendCmd("O", str(int(state)))
def test():
    """ Test.
    driver = BluetoothDriver("00:50:C2:58:56:6B")
    yaw = MerlinOrionHardware(YAW_AXIS, driver)
    pitch = MerlinOrionHardware(PITCH_AXIS, driver)
    shutter = MerlinOrionHardware(SHUTTER_AXIS, driver)
    yaw.init()
    pitch.init()
    yaw.drive(10.)
    pitch.drive(-5.)
    while yaw.getStatus()[1] != '0':
        time.sleep(0.1)
    while pitch.getStatus()[1] != '0':
        time.sleep(0.1)
    shutter.setOutput(1)
    time.sleep(0.5)
    shutter.setOutput(0)
    driver.shutdown()
if __name__ == "__main__":
    """ test() won't be executed if the module is imported.
    test()
You will need to install python, and bluetooth module...
This code is not thread-safe; this mean you can't drive the head from different threads, but as you can see in the test() function, it is possible to drive both axis at the same time.
mikehellers
by mikehellers » Tue Mar 16, 2010 1:21 am
Thanks a lot Frederic. This is perfect to start experimenting.
One quick question to which I couldn't find the answer yet in your script. How can we change the speed of the movement? What is the easiest way to do it?
...mike
by fma38 » Tue Mar 16, 2010 7:44 am
You can't change the speed using the drive command; only the startJog can do that. Have a look at the MerlinOrionPlugins class to see how to use the low-level hardware class, especially the MANUAL_SPEED_TABLE:
http://www.papywizard.org/browser/trunk/papywizard/plugins/merlinOrionPlugins.py#L92
The speed param is the value of the divider used by the controller. Also carefully read the Merlin protocol:
http://www.papywizard.org/wiki/DevelopGuide
by fma38 » Tue Mar 16, 2010 8:55 am
I realized that I didn't implement the low speeds; the code will need to be modified a little bit in the startJog() method. The 'G' command determines the global ratio: I always use 3. If you want to use lower speeds, you will need to use 1.
For more informations, have a look here:
http://sites.google.com/site/rwgastro/SupaTrakMountHacking.pdf
sjhenry
by sjhenry » Thu Apr 08, 2010 6:22 am
Frederic,
Thanks for giving the sample code. I have updated the code with Serial driver to use it with my wired connection.
All,
I also implemented a Bezier curve to make the head go in the curved path. The new code is
License
liability.
Module purpose
Hardware
Implements
 - HardwareError
 - BluetoothDriver
@author: Jones Henry Subbiah
@license: CeCILL
__revision__ = "$Id: merlinOrionHardware.py 2280 2010-02-13 12:27:30Z fma $"
import time
import serial
import math
#import bluetooth
TIMEOUT = 1.
CONNECT_DELAY = 8.
YAW_AXIS = 1
PITCH_AXIS = 2
SHUTTER_AXIS = 1
SERIAL_PORT = "COM4"
SERIAL_BAUDRATE = 9600
class Point:
    """ Point represent the Bezier control points
       x represents yaw and y represents pitch
    def __init__(self, x, y):
        self.x, self.y = float(x), float(y)
    def pprint(self):
        print "(%0.4f, %0.4f)" % (self.x, self.y)
class BezierCurve(object):
    """ class to generate Bezier curve
    def __init__(self, points):
        self._points, self._steps = points, 30
    # Gets input points for a Bezier curve
    # Returns a list of points equals the number of steps the
    # head stops and takes photos.
    def bezier(self):
        outlist = []
        npoints = len(self._points)
        for j in range(self._steps):
            #print "j: %d" % j
            # the increment is always between 0.0 to 1.0
            inc = 1.0 * j / self._steps
            x, y = 0.0, 0.0
            # for each Bezier control points
            for i in range(npoints):
                poly = self.bpoly(npoints-1, i, inc)
                #print "i: %d, inc: %.04f, poly: %.04f" % (i, inc, poly)
                x += self._points[i].x * poly
                y += self._points[i].y * poly
            #print "x: %.04f, y: %.04f" % (x,y)
            outlist.append(Point(x,y))
        # add the last control point. So a step of 300 will result 301 shots
        # not neccessary - just for completeness
        outlist.append(Point(self._points[npoints-1].x,self._points[npoints-1].y))
        return outlist
    # this function calculate optimum number of steps to travel the curve
    # The fov is equal to horizontal FOV of lens used divided by 210.
    # 210 is derived as 7 secs of 30 fps video.
    # update the FOV field. The current one is for 150mm lens on a 1.6 crop camera
    # divided by 210
    # It starts at 30 steps, finds the  curve points, finds the difference of the first
    # 2 points. If it is less than the FOV/210, then that is the minimal steps needed.
    def findsteps(self):
        fov = 0.0410
        steps = 0
        l = []
        while True:
            steps += 30
            self._steps = steps
            l = self.bezier()
            print "steps: %d, l[1].x: %f, l[0].x: %f, diff: %f" % (steps, l[1].x, l[0].x, math.fabs(l[1].x - l[0].x))
            if math.fabs(l[1].x - l[0].x) < fov:
                break
        print "steps: %d" % steps
    # finds the polynomical for a given position
    def bpoly(self, order, position, inc):
        """ Bezier polynomial term
        return self.bcoeff(order, position) * math.pow(inc, position) * math.pow ( 1.0 - inc, (order - position ) )
    # find the coefficient for a given position
    def bcoeff(self, order, position):
        """ Bezier coefficient
        return math.factorial( order ) / ( math.factorial( position ) * math.factorial( order - position ) )
    pass
        try:
            try:
        else:
    def shutdown(self):
        self.__sock.close()
        return size
        else:
            return data
class SerialDriver(object):
    """ Driver for serial connection.
    def __init__(self):
        try:
            self._serial = serial.Serial(port=SERIAL_PORT)
            self._serial.baudrate = SERIAL_BAUDRATE
            self._serial.timeout = TIMEOUT
            self.empty()
        except:
            #Logger().exception("SerialDriver._init()")
            raise
    def shutdown(self):
        self._serial.close()
    def setRTS(self, level):
        """ Set RTS signal to specified level.
        @param level: level to set to RTS signal
        @type level: int
        self._serial.setRTS(level)
    def setDTR(self, level):
        """ Set DTR signal to specified level.
        @param level: level to set to DTR signal
        @type level: int
        self._serial.setDTR(level)
    def setTimeout(self, timeout):
        self._serial.timeout = timeout
    def empty(self):
        if hasattr(self._serial, "inWaiting"):
            self.read(self._serial.inWaiting())
        #Logger().debug("SerialDriver.write(): data=%s" % repr(data))
        size = self._serial.write(data)
        return size
        data = self._serial.read(size)
        #Logger().debug("SerialDriver.read(): data=%s" % repr(data))
            raise IOError("Timeout while reading on serial bus (size=%d, data=%s)" % (size, repr(data)))
        else:
            return data
        self.__axis = axis
        @type strValue: str
        @return: value
        @rtype: int
        value = 0
        for i in xrange(3):
        #print "dav: %s" % value
        return value
        @param value: value
        @type value: int
        @rtype: str
        #print "value %s, eav: %s" % (value, strValue.upper())
        @type codPos: int
        @rtype: float
        value = (codPos - ENCODER_ZERO) * 360. / self.__encoderFullCircle
        #print "e2a: %f" % value
        return value
        @type pos: float
        @rtype: int
        value = int(pos * self.__encoderFullCircle / 360. + ENCODER_ZERO)
        #print "a2e: %d" % value
        return value
        @type cmd: str
        @return: answer
        @rtype: str
        #print "cmd: %s"% cmd
            try:
                answer = ""
                c = ''
                if c == '!':
                answer = ""
                while True:
                    if c == '\r':
                        break
                    answer += c
            except IOError:
            else:
                break
        else:
        return answer
    def init(self):
        # Stop motor
        self.__sendCmd("L")
        # Check motor?
        self.__sendCmd("F")
        # Get sidereal rate
    def read(self):
        @rtype: float
        return pos
        @type state: bool
        """ Drive the axis.
        @type pos: float
        self.__sendCmd("L")
        #self.__sendCmd("j")
        self.__sendCmd("J")
    def stop(self):
        """ Stop the axis.
        self.__sendCmd("L")
        """ Start the axis.
        @type dir_: str
        @param speed: speed
        @type speed: int
        self.__sendCmd("L")
        if dir_ == '+':
        elif dir_ == '-':
        else:
        self.__sendCmd("J")
    def setSpeed(self, speed):
        @rtype: str
def test():
    """ Test.
    driver = SerialDriver()
    lst = []
    lst.append(Point(11.4,14.7))
    lst.append(Point(14.7,1.5))
    lst.append(Point(24.2,14.1))
    lst.append(Point(29.4,2.0))
    bez = BezierCurve(lst)  # initialise the Bezier curve with control points
    bez.findsteps()         # find the minimum number of steps to traverse the curve
    time.sleep(3)           # give time to decide on the step or press Ctrl+C to quit
    cp = bez.bezier()       # calculate the curve points (equals to # of steps + 1)
    yaw.init()
    pitch.init()
    for i in range(len(cp)):
        cp[i].pprint()
        yaw.drive(cp[i].x)
        pitch.drive(cp[i].y)
            time.sleep(0.1)
            time.sleep(0.1)
        # Stabilization delay
        time.sleep(0.5)
        # press the shutter 1/2 second time value
        time.sleep(0.5)
        # delay between shots
        time.sleep(2.0)
    driver.shutdown()
    test()
For those who are not familiar with the Bezier curve, please see her http://en.wikipedia.org/wiki/B%C3%A9zier_curve. You have to update the code part below to match your positions.
The example video is http://www.vimeo.com/10767739. This is just out of the camera. The head is not that accurate in moving the curved path so it is resulting in zig-zag motion.
In order to solve this problem, the DeSahker plugin http://www.sundancemediagroup.com/articles/deshaker_guide.htm for VirtualDub is used to stabilize the shot. This is mandatory step for making the video look steady. After the stabilization, you can see the video at http://www.vimeo.com/10767843
Jones
by fma38 » Thu Apr 08, 2010 6:45 am
This is really great work, Jones!
claudevh
by claudevh » Thu Apr 08, 2010 8:57 am
Excellent addition Jones,
This get some forms now ...
(P.S. For using this last version Pyserial should be installed also ...)
by fma38 » Thu Apr 08, 2010 11:58 am
Do you plan to integrate the Bezier generator to the Timelapse preset generator?
sjhenry
by sjhenry » Fri Apr 09, 2010 12:21 am
Thank you Frederic and Claude!
Yes. I have a Bezier generator for time lapse as well. I have not yet merged that to the current time lapse generator. I am thinking of leaving the old one as it is and upload the new one. The reason is that the Bezier curve becomes a straight line (which the old time lapse is handling) if only two control points are used. That straight line could be any orientation and finer movements with the new Bezier one. The new generator also includes the general rule of thumb of moving the head for at least 7 seconds to cross the FOV of the lens that will result in a smoother motion.
Is there a rounding done inside the Papywizard code when reading the yaw and pitch values from the preset xml? The new generator generates up to 4 decimal place of accuracy for the yaw and pitch values. I want to make sure it is sent all the way to head without any rounding happening in the middle.
Jones
sjhenry
by sjhenry » Fri Apr 09, 2010 12:23 am
The only thing I have not figured out using the Bezier is that how to do the smooth in/out or ramp up/down. I'll upload the new one soon here.
Jones
by fma38 » Fri Apr 09, 2010 6:22 am
I don't think I round values from preset, but the Merlin accuracy does ;)
sjhenry
by sjhenry » Sat Apr 10, 2010 6:59 am
Thanks for the info Frederic. I have uploaded the new preset generator in a separate thread.
Jones
Previous
