Merlin, Orion and Papywizard motion timelapse examples ?
JohnM
by JohnM » Fri Oct 23, 2009 7:45 pm
Hi fellow Autopaners and timelapsers.
I`ve been away from this forum for quite a while and have to update on status quo pretty fast.
There is probably some threads with examples, but I hope I dont break forum etiquette too much by asking rather than reading up on all the threads:
Do you have any links to share to hi quality motion timelapse done with the Papywizard setup ?
Feedback would be highly appreciated.
Sincerly: John Myrstad
by fma38 » Fri Oct 23, 2009 8:55 pm
Papywizard does not (yet) support timelapse. But Jones wrote a great preset generator, that will allow you to make timelapse. See:
http://www.autopano.net/forum/t6748-papywizard-timelapse-preset-generator
Hope this helps.
JohnM
by JohnM » Sat Oct 24, 2009 12:13 pm
May I use the preset generator to actually make a motion timelapse with the current hardware/software, and if yes, has anyone made motion controlled timelapse with it ?
claudevh
by claudevh » Sat Oct 24, 2009 5:30 pm
Hi John,
What do-you have as equipment actually ?
Do-you have a Merlin head, BT module and Papywizard ?
Wich type of camera ?
To answer your questions:
May I use the preset generator to actually make a motion timelapse with the current hardware/software ?
YES ! :)
YES ! :)
Only for testing ... if you have a camera who can be connected to the Merlin, this work perfectly ... I use a Canon G10 for this purpose !
You have the controls of :
- firing the camera exactly with the interval you want, this interval could be changed at different place in the script if necessary.
- full control of Pitch and Yaw
- Astronomic tracking is possible but difficult to synchronize with camera firing except if this firing is autonomous on the camera(eg. external controler, Canon Chdk of other way's)
- the Merlin displacements between the different positions are not continuous, I mean the Merlin move between each camera firingand stop for firing, this is excellent for eliminating blur's but cause sometime some 'flickering" ...
This is very powerfull but not very flexible, this need some preparations in advance ...
You can ask also to the "scripts" father "sjhenry", he has certainly used his own script, isn't ? ;)
:cool: Claude :cool:
JohnM
by JohnM » Sat Oct 24, 2009 6:38 pm
I havent any hardware yet, I just have to check if its possible to do high quality motion timelapse with the combination. If theres a (some) user case(s) with smooth motion timelapse available for me to see, I`ll probably buy one or two ASAP.
I just have to see a motion timelapse movie first.
sjhenry
by sjhenry » Thu Oct 29, 2009 1:30 am
John,
I have shot only one timelapse sequence thus far using the Merlin/Papywizard due to lack of my time. I uploaded it in Vimeo and the URL is http://vimeo.com/7319406. This is an example clip.
Camera: 450D (Rebel XSI)
Lens: EF-S 55-250 (used at 250mm)
Time between each frame is set to a total of 6 secs. Please see the other thread http://www.autopano.net/forum/t6748-papywizard-timelapse-preset-generatoron how to set it.
The clip has three segment to it with no sound.
The first segment is taken with the following preset that moves the head from right to left.
<?xml version="1.0" encoding="utf-8"?>
<papywizard>
    <preset name="180_1_0_0.2">
        <tooltip>
            TimeLapse preset for 180 positions with 0 pitch increment and 0.2 yaw increment
        </tooltip>
        <shoot>
            <pict yaw="-0.0" pitch="0.0"/>
            <pict yaw="-0.2" pitch="0.0"/>
            <pict yaw="-0.4" pitch="0.0"/>
            <pict yaw="-0.6" pitch="0.0"/>
            <pict yaw="-0.8" pitch="0.0"/>
            <pict yaw="-1.0" pitch="0.0"/>
            <pict yaw="-1.2" pitch="0.0"/>
            <pict yaw="-1.4" pitch="0.0"/>
            <pict yaw="-1.6" pitch="0.0"/>
            <pict yaw="-1.8" pitch="0.0"/>
            <pict yaw="-2.0" pitch="0.0"/>
            <pict yaw="-2.2" pitch="0.0"/>
            <pict yaw="-2.4" pitch="0.0"/>
            <pict yaw="-2.6" pitch="0.0"/>
            <pict yaw="-2.8" pitch="0.0"/>
            <pict yaw="-3.0" pitch="0.0"/>
            <pict yaw="-3.2" pitch="0.0"/>
            <pict yaw="-3.4" pitch="0.0"/>
            <pict yaw="-3.6" pitch="0.0"/>
            <pict yaw="-3.8" pitch="0.0"/>
            <pict yaw="-4.0" pitch="0.0"/>
            <pict yaw="-4.2" pitch="0.0"/>
            <pict yaw="-4.4" pitch="0.0"/>
            <pict yaw="-4.6" pitch="0.0"/>
            <pict yaw="-4.8" pitch="0.0"/>
            <pict yaw="-5.0" pitch="0.0"/>
            <pict yaw="-5.2" pitch="0.0"/>
            <pict yaw="-5.4" pitch="0.0"/>
            <pict yaw="-5.6" pitch="0.0"/>
            <pict yaw="-5.8" pitch="0.0"/>
            <pict yaw="-6.0" pitch="0.0"/>
            <pict yaw="-6.2" pitch="0.0"/>
            <pict yaw="-6.4" pitch="0.0"/>
            <pict yaw="-6.6" pitch="0.0"/>
            <pict yaw="-6.8" pitch="0.0"/>
            <pict yaw="-7.0" pitch="0.0"/>
            <pict yaw="-7.2" pitch="0.0"/>
            <pict yaw="-7.4" pitch="0.0"/>
            <pict yaw="-7.6" pitch="0.0"/>
            <pict yaw="-7.8" pitch="0.0"/>
            <pict yaw="-8.0" pitch="0.0"/>
            <pict yaw="-8.2" pitch="0.0"/>
            <pict yaw="-8.4" pitch="0.0"/>
            <pict yaw="-8.6" pitch="0.0"/>
            <pict yaw="-8.8" pitch="0.0"/>
            <pict yaw="-9.0" pitch="0.0"/>
            <pict yaw="-9.2" pitch="0.0"/>
            <pict yaw="-9.4" pitch="0.0"/>
            <pict yaw="-9.6" pitch="0.0"/>
            <pict yaw="-9.8" pitch="0.0"/>
            <pict yaw="-10.0" pitch="0.0"/>
            <pict yaw="-10.2" pitch="0.0"/>
            <pict yaw="-10.4" pitch="0.0"/>
            <pict yaw="-10.6" pitch="0.0"/>
            <pict yaw="-10.8" pitch="0.0"/>
            <pict yaw="-11.0" pitch="0.0"/>
            <pict yaw="-11.2" pitch="0.0"/>
            <pict yaw="-11.4" pitch="0.0"/>
            <pict yaw="-11.6" pitch="0.0"/>
            <pict yaw="-11.8" pitch="0.0"/>
            <pict yaw="-12.0" pitch="0.0"/>
            <pict yaw="-12.2" pitch="0.0"/>
            <pict yaw="-12.4" pitch="0.0"/>
            <pict yaw="-12.6" pitch="0.0"/>
            <pict yaw="-12.8" pitch="0.0"/>
            <pict yaw="-13.0" pitch="0.0"/>
            <pict yaw="-13.2" pitch="0.0"/>
            <pict yaw="-13.4" pitch="0.0"/>
            <pict yaw="-13.6" pitch="0.0"/>
            <pict yaw="-13.8" pitch="0.0"/>
            <pict yaw="-14.0" pitch="0.0"/>
            <pict yaw="-14.2" pitch="0.0"/>
            <pict yaw="-14.4" pitch="0.0"/>
            <pict yaw="-14.6" pitch="0.0"/>
            <pict yaw="-14.8" pitch="0.0"/>
            <pict yaw="-15.0" pitch="0.0"/>
            <pict yaw="-15.2" pitch="0.0"/>
            <pict yaw="-15.4" pitch="0.0"/>
            <pict yaw="-15.6" pitch="0.0"/>
            <pict yaw="-15.8" pitch="0.0"/>
            <pict yaw="-16.0" pitch="0.0"/>
            <pict yaw="-16.2" pitch="0.0"/>
            <pict yaw="-16.4" pitch="0.0"/>
            <pict yaw="-16.6" pitch="0.0"/>
            <pict yaw="-16.8" pitch="0.0"/>
            <pict yaw="-17.0" pitch="0.0"/>
            <pict yaw="-17.2" pitch="0.0"/>
            <pict yaw="-17.4" pitch="0.0"/>
            <pict yaw="-17.6" pitch="0.0"/>
            <pict yaw="-17.8" pitch="0.0"/>
            <pict yaw="-18.0" pitch="0.0"/>
            <pict yaw="-18.2" pitch="0.0"/>
            <pict yaw="-18.4" pitch="0.0"/>
            <pict yaw="-18.6" pitch="0.0"/>
            <pict yaw="-18.8" pitch="0.0"/>
            <pict yaw="-19.0" pitch="0.0"/>
            <pict yaw="-19.2" pitch="0.0"/>
            <pict yaw="-19.4" pitch="0.0"/>
            <pict yaw="-19.6" pitch="0.0"/>
            <pict yaw="-19.8" pitch="0.0"/>
            <pict yaw="-20.0" pitch="0.0"/>
            <pict yaw="-20.2" pitch="0.0"/>
            <pict yaw="-20.4" pitch="0.0"/>
            <pict yaw="-20.6" pitch="0.0"/>
            <pict yaw="-20.8" pitch="0.0"/>
            <pict yaw="-21.0" pitch="0.0"/>
            <pict yaw="-21.2" pitch="0.0"/>
            <pict yaw="-21.4" pitch="0.0"/>
            <pict yaw="-21.6" pitch="0.0"/>
            <pict yaw="-21.8" pitch="0.0"/>
            <pict yaw="-22.0" pitch="0.0"/>
            <pict yaw="-22.2" pitch="0.0"/>
            <pict yaw="-22.4" pitch="0.0"/>
            <pict yaw="-22.6" pitch="0.0"/>
            <pict yaw="-22.8" pitch="0.0"/>
            <pict yaw="-23.0" pitch="0.0"/>
            <pict yaw="-23.2" pitch="0.0"/>
            <pict yaw="-23.4" pitch="0.0"/>
            <pict yaw="-23.6" pitch="0.0"/>
            <pict yaw="-23.8" pitch="0.0"/>
            <pict yaw="-24.0" pitch="0.0"/>
            <pict yaw="-24.2" pitch="0.0"/>
            <pict yaw="-24.4" pitch="0.0"/>
            <pict yaw="-24.6" pitch="0.0"/>
            <pict yaw="-24.8" pitch="0.0"/>
            <pict yaw="-25.0" pitch="0.0"/>
            <pict yaw="-25.2" pitch="0.0"/>
            <pict yaw="-25.4" pitch="0.0"/>
            <pict yaw="-25.6" pitch="0.0"/>
            <pict yaw="-25.8" pitch="0.0"/>
            <pict yaw="-26.0" pitch="0.0"/>
            <pict yaw="-26.2" pitch="0.0"/>
            <pict yaw="-26.4" pitch="0.0"/>
            <pict yaw="-26.6" pitch="0.0"/>
            <pict yaw="-26.8" pitch="0.0"/>
            <pict yaw="-27.0" pitch="0.0"/>
            <pict yaw="-27.2" pitch="0.0"/>
            <pict yaw="-27.4" pitch="0.0"/>
            <pict yaw="-27.6" pitch="0.0"/>
            <pict yaw="-27.8" pitch="0.0"/>
            <pict yaw="-28.0" pitch="0.0"/>
            <pict yaw="-28.2" pitch="0.0"/>
            <pict yaw="-28.4" pitch="0.0"/>
            <pict yaw="-28.6" pitch="0.0"/>
            <pict yaw="-28.8" pitch="0.0"/>
            <pict yaw="-29.0" pitch="0.0"/>
            <pict yaw="-29.2" pitch="0.0"/>
            <pict yaw="-29.4" pitch="0.0"/>
            <pict yaw="-29.6" pitch="0.0"/>
            <pict yaw="-29.8" pitch="0.0"/>
            <pict yaw="-30.0" pitch="0.0"/>
            <pict yaw="-30.2" pitch="0.0"/>
            <pict yaw="-30.4" pitch="0.0"/>
            <pict yaw="-30.6" pitch="0.0"/>
            <pict yaw="-30.8" pitch="0.0"/>
            <pict yaw="-31.0" pitch="0.0"/>
            <pict yaw="-31.2" pitch="0.0"/>
            <pict yaw="-31.4" pitch="0.0"/>
            <pict yaw="-31.6" pitch="0.0"/>
            <pict yaw="-31.8" pitch="0.0"/>
            <pict yaw="-32.0" pitch="0.0"/>
            <pict yaw="-32.2" pitch="0.0"/>
            <pict yaw="-32.4" pitch="0.0"/>
            <pict yaw="-32.6" pitch="0.0"/>
            <pict yaw="-32.8" pitch="0.0"/>
            <pict yaw="-33.0" pitch="0.0"/>
            <pict yaw="-33.2" pitch="0.0"/>
            <pict yaw="-33.4" pitch="0.0"/>
            <pict yaw="-33.6" pitch="0.0"/>
            <pict yaw="-33.8" pitch="0.0"/>
            <pict yaw="-34.0" pitch="0.0"/>
            <pict yaw="-34.2" pitch="0.0"/>
            <pict yaw="-34.4" pitch="0.0"/>
            <pict yaw="-34.6" pitch="0.0"/>
            <pict yaw="-34.8" pitch="0.0"/>
            <pict yaw="-35.0" pitch="0.0"/>
            <pict yaw="-35.2" pitch="0.0"/>
            <pict yaw="-35.4" pitch="0.0"/>
            <pict yaw="-35.6" pitch="0.0"/>
            <pict yaw="-35.8" pitch="0.0"/>
        </shoot>
    </preset>
</papywizard>
The second segment is done using the following preset from left to right. This preset has four stages in it. The first stage is to move the head slowly. Then partial preset is generated to speed up 3 times the starting stage. Then another partial preset is generated to go back to the normal speed. Then another partial preset is generated to stay for a second at the end. All these three were combined together and got the following preset.
<papywizard>
    <preset name="72_1_0_0.1">
        <tooltip>
            TimeLapse preset for 72 positions with 0 pitch increment and 0.1 yaw increment
        </tooltip>
        <shoot>
            <pict yaw="+0.0" pitch="0.0"/>
            <pict yaw="+0.1" pitch="0.0"/>
            <pict yaw="+0.2" pitch="0.0"/>
            <pict yaw="+0.3" pitch="0.0"/>
            <pict yaw="+0.4" pitch="0.0"/>
            <pict yaw="+0.5" pitch="0.0"/>
            <pict yaw="+0.6" pitch="0.0"/>
            <pict yaw="+0.7" pitch="0.0"/>
            <pict yaw="+0.8" pitch="0.0"/>
            <pict yaw="+0.9" pitch="0.0"/>
            <pict yaw="+1.0" pitch="0.0"/>
            <pict yaw="+1.1" pitch="0.0"/>
            <pict yaw="+1.2" pitch="0.0"/>
            <pict yaw="+1.3" pitch="0.0"/>
            <pict yaw="+1.4" pitch="0.0"/>
            <pict yaw="+1.5" pitch="0.0"/>
            <pict yaw="+1.6" pitch="0.0"/>
            <pict yaw="+1.7" pitch="0.0"/>
            <pict yaw="+1.8" pitch="0.0"/>
            <pict yaw="+1.9" pitch="0.0"/>
            <pict yaw="+2.0" pitch="0.0"/>
            <pict yaw="+2.1" pitch="0.0"/>
            <pict yaw="+2.2" pitch="0.0"/>
            <pict yaw="+2.3" pitch="0.0"/>
            <pict yaw="+2.4" pitch="0.0"/>
            <pict yaw="+2.5" pitch="0.0"/>
            <pict yaw="+2.6" pitch="0.0"/>
            <pict yaw="+2.7" pitch="0.0"/>
            <pict yaw="+2.8" pitch="0.0"/>
            <pict yaw="+2.9" pitch="0.0"/>
            <pict yaw="+3.0" pitch="0.0"/>
            <pict yaw="+3.1" pitch="0.0"/>
            <pict yaw="+3.2" pitch="0.0"/>
            <pict yaw="+3.3" pitch="0.0"/>
            <pict yaw="+3.4" pitch="0.0"/>
            <pict yaw="+3.5" pitch="0.0"/>
            <pict yaw="+3.6" pitch="0.0"/>
            <pict yaw="+3.7" pitch="0.0"/>
            <pict yaw="+3.8" pitch="0.0"/>
            <pict yaw="+3.9" pitch="0.0"/>
            <pict yaw="+4.0" pitch="0.0"/>
            <pict yaw="+4.1" pitch="0.0"/>
            <pict yaw="+4.2" pitch="0.0"/>
            <pict yaw="+4.3" pitch="0.0"/>
            <pict yaw="+4.4" pitch="0.0"/>
            <pict yaw="+4.5" pitch="0.0"/>
            <pict yaw="+4.6" pitch="0.0"/>
            <pict yaw="+4.7" pitch="0.0"/>
            <pict yaw="+4.8" pitch="0.0"/>
            <pict yaw="+4.9" pitch="0.0"/>
            <pict yaw="+5.0" pitch="0.0"/>
            <pict yaw="+5.1" pitch="0.0"/>
            <pict yaw="+5.2" pitch="0.0"/>
            <pict yaw="+5.3" pitch="0.0"/>
            <pict yaw="+5.4" pitch="0.0"/>
            <pict yaw="+5.5" pitch="0.0"/>
            <pict yaw="+5.6" pitch="0.0"/>
            <pict yaw="+5.7" pitch="0.0"/>
            <pict yaw="+5.8" pitch="0.0"/>
            <pict yaw="+5.9" pitch="0.0"/>
            <pict yaw="+6.0" pitch="0.0"/>
            <pict yaw="+6.1" pitch="0.0"/>
            <pict yaw="+6.2" pitch="0.0"/>
            <pict yaw="+6.3" pitch="0.0"/>
            <pict yaw="+6.4" pitch="0.0"/>
            <pict yaw="+6.5" pitch="0.0"/>
            <pict yaw="+6.6" pitch="0.0"/>
            <pict yaw="+6.7" pitch="0.0"/>
            <pict yaw="+6.8" pitch="0.0"/>
            <pict yaw="+6.9" pitch="0.0"/>
            <pict yaw="+7.0" pitch="0.0"/>
            <pict yaw="+7.1" pitch="0.0"/>
            <pict yaw="+7.4" pitch="0.0"/>
            <pict yaw="+7.7" pitch="0.0"/>
            <pict yaw="+8.0" pitch="0.0"/>
            <pict yaw="+8.3" pitch="0.0"/>
            <pict yaw="+8.6" pitch="0.0"/>
            <pict yaw="+8.9" pitch="0.0"/>
            <pict yaw="+9.2" pitch="0.0"/>
            <pict yaw="+9.5" pitch="0.0"/>
            <pict yaw="+9.8" pitch="0.0"/>
            <pict yaw="+10.1" pitch="0.0"/>
            <pict yaw="+10.4" pitch="0.0"/>
            <pict yaw="+10.7" pitch="0.0"/>
            <pict yaw="+11.0" pitch="0.0"/>
            <pict yaw="+11.3" pitch="0.0"/>
            <pict yaw="+11.6" pitch="0.0"/>
            <pict yaw="+11.9" pitch="0.0"/>
            <pict yaw="+12.2" pitch="0.0"/>
            <pict yaw="+12.5" pitch="0.0"/>
            <pict yaw="+12.8" pitch="0.0"/>
            <pict yaw="+13.1" pitch="0.0"/>
            <pict yaw="+13.4" pitch="0.0"/>
            <pict yaw="+13.7" pitch="0.0"/>
            <pict yaw="+14.0" pitch="0.0"/>
            <pict yaw="+14.3" pitch="0.0"/>
            <pict yaw="+14.6" pitch="0.0"/>
            <pict yaw="+14.9" pitch="0.0"/>
            <pict yaw="+15.2" pitch="0.0"/>
            <pict yaw="+15.5" pitch="0.0"/>
            <pict yaw="+15.8" pitch="0.0"/>
            <pict yaw="+16.1" pitch="0.0"/>
            <pict yaw="+16.4" pitch="0.0"/>
            <pict yaw="+16.7" pitch="0.0"/>
            <pict yaw="+17.0" pitch="0.0"/>
            <pict yaw="+17.3" pitch="0.0"/>
            <pict yaw="+17.6" pitch="0.0"/>
            <pict yaw="+17.9" pitch="0.0"/>
            <pict yaw="+18.2" pitch="0.0"/>
            <pict yaw="+18.5" pitch="0.0"/>
            <pict yaw="+18.8" pitch="0.0"/>
            <pict yaw="+19.1" pitch="0.0"/>
            <pict yaw="+19.4" pitch="0.0"/>
            <pict yaw="+19.7" pitch="0.0"/>
            <pict yaw="+20.0" pitch="0.0"/>
            <pict yaw="+20.3" pitch="0.0"/>
            <pict yaw="+20.6" pitch="0.0"/>
            <pict yaw="+20.9" pitch="0.0"/>
            <pict yaw="+21.2" pitch="0.0"/>
            <pict yaw="+21.5" pitch="0.0"/>
            <pict yaw="+21.8" pitch="0.0"/>
            <pict yaw="+22.1" pitch="0.0"/>
            <pict yaw="+22.4" pitch="0.0"/>
            <pict yaw="+22.7" pitch="0.0"/>
            <pict yaw="+23.0" pitch="0.0"/>
            <pict yaw="+23.3" pitch="0.0"/>
            <pict yaw="+23.6" pitch="0.0"/>
            <pict yaw="+23.9" pitch="0.0"/>
            <pict yaw="+24.2" pitch="0.0"/>
            <pict yaw="+24.5" pitch="0.0"/>
            <pict yaw="+24.8" pitch="0.0"/>
            <pict yaw="+25.1" pitch="0.0"/>
            <pict yaw="+25.4" pitch="0.0"/>
            <pict yaw="+25.7" pitch="0.0"/>
            <pict yaw="+26.0" pitch="0.0"/>
            <pict yaw="+26.3" pitch="0.0"/>
            <pict yaw="+26.6" pitch="0.0"/>
            <pict yaw="+26.9" pitch="0.0"/>
            <pict yaw="+27.2" pitch="0.0"/>
            <pict yaw="+27.5" pitch="0.0"/>
            <pict yaw="+27.8" pitch="0.0"/>
            <pict yaw="+28.1" pitch="0.0"/>
            <pict yaw="+28.4" pitch="0.0"/>
            <pict yaw="+28.7" pitch="0.0"/>
            <pict yaw="+28.8" pitch="0.0"/>
            <pict yaw="+28.9" pitch="0.0"/>
            <pict yaw="+29.0" pitch="0.0"/>
            <pict yaw="+29.1" pitch="0.0"/>
            <pict yaw="+29.2" pitch="0.0"/>
            <pict yaw="+29.3" pitch="0.0"/>
            <pict yaw="+29.4" pitch="0.0"/>
            <pict yaw="+29.5" pitch="0.0"/>
            <pict yaw="+29.6" pitch="0.0"/>
            <pict yaw="+29.7" pitch="0.0"/>
            <pict yaw="+29.8" pitch="0.0"/>
            <pict yaw="+29.9" pitch="0.0"/>
            <pict yaw="+30.0" pitch="0.0"/>
            <pict yaw="+30.1" pitch="0.0"/>
            <pict yaw="+30.2" pitch="0.0"/>
            <pict yaw="+30.3" pitch="0.0"/>
            <pict yaw="+30.4" pitch="0.0"/>
            <pict yaw="+30.5" pitch="0.0"/>
            <pict yaw="+30.6" pitch="0.0"/>
            <pict yaw="+30.7" pitch="0.0"/>
            <pict yaw="+30.8" pitch="0.0"/>
            <pict yaw="+30.9" pitch="0.0"/>
            <pict yaw="+31.0" pitch="0.0"/>
            <pict yaw="+31.1" pitch="0.0"/>
            <pict yaw="+31.2" pitch="0.0"/>
            <pict yaw="+31.3" pitch="0.0"/>
            <pict yaw="+31.4" pitch="0.0"/>
            <pict yaw="+31.5" pitch="0.0"/>
            <pict yaw="+31.6" pitch="0.0"/>
            <pict yaw="+31.7" pitch="0.0"/>
            <pict yaw="+31.8" pitch="0.0"/>
            <pict yaw="+31.9" pitch="0.0"/>
            <pict yaw="+32.0" pitch="0.0"/>
            <pict yaw="+32.1" pitch="0.0"/>
            <pict yaw="+32.2" pitch="0.0"/>
            <pict yaw="+32.3" pitch="0.0"/>
            <pict yaw="+32.4" pitch="0.0"/>
            <pict yaw="+32.5" pitch="0.0"/>
            <pict yaw="+32.6" pitch="0.0"/>
            <pict yaw="+32.7" pitch="0.0"/>
            <pict yaw="+32.8" pitch="0.0"/>
            <pict yaw="+32.9" pitch="0.0"/>
            <pict yaw="+33.0" pitch="0.0"/>
            <pict yaw="+33.1" pitch="0.0"/>
            <pict yaw="+33.2" pitch="0.0"/>
            <pict yaw="+33.3" pitch="0.0"/>
            <pict yaw="+33.4" pitch="0.0"/>
            <pict yaw="+33.5" pitch="0.0"/>
            <pict yaw="+33.6" pitch="0.0"/>
            <pict yaw="+33.7" pitch="0.0"/>
            <pict yaw="+33.8" pitch="0.0"/>
            <pict yaw="+33.9" pitch="0.0"/>
            <pict yaw="+34.0" pitch="0.0"/>
            <pict yaw="+34.1" pitch="0.0"/>
            <pict yaw="+34.2" pitch="0.0"/>
            <pict yaw="+34.3" pitch="0.0"/>
            <pict yaw="+34.4" pitch="0.0"/>
            <pict yaw="+34.5" pitch="0.0"/>
            <pict yaw="+34.6" pitch="0.0"/>
            <pict yaw="+34.7" pitch="0.0"/>
            <pict yaw="+34.8" pitch="0.0"/>
            <pict yaw="+34.9" pitch="0.0"/>
            <pict yaw="+35.0" pitch="0.0"/>
            <pict yaw="+35.1" pitch="0.0"/>
            <pict yaw="+35.2" pitch="0.0"/>
            <pict yaw="+35.3" pitch="0.0"/>
            <pict yaw="+35.4" pitch="0.0"/>
            <pict yaw="+35.5" pitch="0.0"/>
            <pict yaw="+35.6" pitch="0.0"/>
            <pict yaw="+35.7" pitch="0.0"/>
            <pict yaw="+35.8" pitch="0.0"/>
            <pict yaw="+35.9" pitch="0.0"/>
            <pict yaw="+36.0" pitch="0.0"/>
            <pict yaw="+36.1" pitch="0.0"/>
            <pict yaw="+36.2" pitch="0.0"/>
            <pict yaw="+36.3" pitch="0.0"/>
            <pict yaw="+36.4" pitch="0.0"/>
            <pict yaw="+36.5" pitch="0.0"/>
            <pict yaw="+36.6" pitch="0.0"/>
            <pict yaw="+36.7" pitch="0.0"/>
            <pict yaw="+36.8" pitch="0.0"/>
            <pict yaw="+36.9" pitch="0.0"/>
            <pict yaw="+37.0" pitch="0.0"/>
            <pict yaw="+37.1" pitch="0.0"/>
            <pict yaw="+37.2" pitch="0.0"/>
            <pict yaw="+37.3" pitch="0.0"/>
            <pict yaw="+37.4" pitch="0.0"/>
            <pict yaw="+37.5" pitch="0.0"/>
            <pict yaw="+37.6" pitch="0.0"/>
            <pict yaw="+37.7" pitch="0.0"/>
            <pict yaw="+37.8" pitch="0.0"/>
            <pict yaw="+37.9" pitch="0.0"/>
            <pict yaw="+38.0" pitch="0.0"/>
            <pict yaw="+38.1" pitch="0.0"/>
            <pict yaw="+38.2" pitch="0.0"/>
            <pict yaw="38.2" pitch="0.0"/>
        </shoot>
    </preset>
</papywizard>
The third segment is done by using the following preset from bottom to top but stopped in the middle.
<papywizard>
    <preset name="140_1_0.1_0">
        <tooltip>
            TimeLapse preset for 140 positions with 0.1 pitch increment and 0 yaw increment
        </tooltip>
        <shoot>
            <pict yaw="0.0" pitch="+0.0"/>
            <pict yaw="0.0" pitch="+0.1"/>
            <pict yaw="0.0" pitch="+0.2"/>
            <pict yaw="0.0" pitch="+0.3"/>
            <pict yaw="0.0" pitch="+0.4"/>
            <pict yaw="0.0" pitch="+0.5"/>
            <pict yaw="0.0" pitch="+0.6"/>
            <pict yaw="0.0" pitch="+0.7"/>
            <pict yaw="0.0" pitch="+0.8"/>
            <pict yaw="0.0" pitch="+0.9"/>
            <pict yaw="0.0" pitch="+1.0"/>
            <pict yaw="0.0" pitch="+1.1"/>
            <pict yaw="0.0" pitch="+1.2"/>
            <pict yaw="0.0" pitch="+1.3"/>
            <pict yaw="0.0" pitch="+1.4"/>
            <pict yaw="0.0" pitch="+1.5"/>
            <pict yaw="0.0" pitch="+1.6"/>
            <pict yaw="0.0" pitch="+1.7"/>
            <pict yaw="0.0" pitch="+1.8"/>
            <pict yaw="0.0" pitch="+1.9"/>
            <pict yaw="0.0" pitch="+2.0"/>
            <pict yaw="0.0" pitch="+2.1"/>
            <pict yaw="0.0" pitch="+2.2"/>
            <pict yaw="0.0" pitch="+2.3"/>
            <pict yaw="0.0" pitch="+2.4"/>
            <pict yaw="0.0" pitch="+2.5"/>
            <pict yaw="0.0" pitch="+2.6"/>
            <pict yaw="0.0" pitch="+2.7"/>
            <pict yaw="0.0" pitch="+2.8"/>
            <pict yaw="0.0" pitch="+2.9"/>
            <pict yaw="0.0" pitch="+3.0"/>
            <pict yaw="0.0" pitch="+3.1"/>
            <pict yaw="0.0" pitch="+3.2"/>
            <pict yaw="0.0" pitch="+3.3"/>
            <pict yaw="0.0" pitch="+3.4"/>
            <pict yaw="0.0" pitch="+3.5"/>
            <pict yaw="0.0" pitch="+3.6"/>
            <pict yaw="0.0" pitch="+3.7"/>
            <pict yaw="0.0" pitch="+3.8"/>
            <pict yaw="0.0" pitch="+3.9"/>
            <pict yaw="0.0" pitch="+4.0"/>
            <pict yaw="0.0" pitch="+4.1"/>
            <pict yaw="0.0" pitch="+4.2"/>
            <pict yaw="0.0" pitch="+4.3"/>
            <pict yaw="0.0" pitch="+4.4"/>
            <pict yaw="0.0" pitch="+4.5"/>
            <pict yaw="0.0" pitch="+4.6"/>
            <pict yaw="0.0" pitch="+4.7"/>
            <pict yaw="0.0" pitch="+4.8"/>
            <pict yaw="0.0" pitch="+4.9"/>
            <pict yaw="0.0" pitch="+5.0"/>
            <pict yaw="0.0" pitch="+5.1"/>
            <pict yaw="0.0" pitch="+5.2"/>
            <pict yaw="0.0" pitch="+5.3"/>
            <pict yaw="0.0" pitch="+5.4"/>
            <pict yaw="0.0" pitch="+5.5"/>
            <pict yaw="0.0" pitch="+5.6"/>
            <pict yaw="0.0" pitch="+5.7"/>
            <pict yaw="0.0" pitch="+5.8"/>
            <pict yaw="0.0" pitch="+5.9"/>
            <pict yaw="0.0" pitch="+6.0"/>
            <pict yaw="0.0" pitch="+6.1"/>
            <pict yaw="0.0" pitch="+6.2"/>
            <pict yaw="0.0" pitch="+6.3"/>
            <pict yaw="0.0" pitch="+6.4"/>
            <pict yaw="0.0" pitch="+6.5"/>
            <pict yaw="0.0" pitch="+6.6"/>
            <pict yaw="0.0" pitch="+6.7"/>
            <pict yaw="0.0" pitch="+6.8"/>
            <pict yaw="0.0" pitch="+6.9"/>
            <pict yaw="0.0" pitch="+7.0"/>
            <pict yaw="0.0" pitch="+7.1"/>
            <pict yaw="0.0" pitch="+7.2"/>
            <pict yaw="0.0" pitch="+7.3"/>
            <pict yaw="0.0" pitch="+7.4"/>
            <pict yaw="0.0" pitch="+7.5"/>
            <pict yaw="0.0" pitch="+7.6"/>
            <pict yaw="0.0" pitch="+7.7"/>
            <pict yaw="0.0" pitch="+7.8"/>
            <pict yaw="0.0" pitch="+7.9"/>
            <pict yaw="0.0" pitch="+8.0"/>
            <pict yaw="0.0" pitch="+8.1"/>
            <pict yaw="0.0" pitch="+8.2"/>
            <pict yaw="0.0" pitch="+8.3"/>
            <pict yaw="0.0" pitch="+8.4"/>
            <pict yaw="0.0" pitch="+8.5"/>
            <pict yaw="0.0" pitch="+8.6"/>
            <pict yaw="0.0" pitch="+8.7"/>
            <pict yaw="0.0" pitch="+8.8"/>
            <pict yaw="0.0" pitch="+8.9"/>
            <pict yaw="0.0" pitch="+9.0"/>
            <pict yaw="0.0" pitch="+9.1"/>
            <pict yaw="0.0" pitch="+9.2"/>
            <pict yaw="0.0" pitch="+9.3"/>
            <pict yaw="0.0" pitch="+9.4"/>
            <pict yaw="0.0" pitch="+9.5"/>
            <pict yaw="0.0" pitch="+9.6"/>
            <pict yaw="0.0" pitch="+9.7"/>
            <pict yaw="0.0" pitch="+9.8"/>
            <pict yaw="0.0" pitch="+9.9"/>
            <pict yaw="0.0" pitch="+10.0"/>
            <pict yaw="0.0" pitch="+10.1"/>
            <pict yaw="0.0" pitch="+10.2"/>
            <pict yaw="0.0" pitch="+10.3"/>
            <pict yaw="0.0" pitch="+10.4"/>
            <pict yaw="0.0" pitch="+10.5"/>
            <pict yaw="0.0" pitch="+10.6"/>
            <pict yaw="0.0" pitch="+10.7"/>
            <pict yaw="0.0" pitch="+10.8"/>
            <pict yaw="0.0" pitch="+10.9"/>
            <pict yaw="0.0" pitch="+11.0"/>
            <pict yaw="0.0" pitch="+11.1"/>
            <pict yaw="0.0" pitch="+11.2"/>
            <pict yaw="0.0" pitch="+11.3"/>
            <pict yaw="0.0" pitch="+11.4"/>
            <pict yaw="0.0" pitch="+11.5"/>
            <pict yaw="0.0" pitch="+11.6"/>
            <pict yaw="0.0" pitch="+11.7"/>
            <pict yaw="0.0" pitch="+11.8"/>
            <pict yaw="0.0" pitch="+11.9"/>
            <pict yaw="0.0" pitch="+12.0"/>
            <pict yaw="0.0" pitch="+12.1"/>
            <pict yaw="0.0" pitch="+12.2"/>
            <pict yaw="0.0" pitch="+12.3"/>
            <pict yaw="0.0" pitch="+12.4"/>
            <pict yaw="0.0" pitch="+12.5"/>
            <pict yaw="0.0" pitch="+12.6"/>
            <pict yaw="0.0" pitch="+12.7"/>
            <pict yaw="0.0" pitch="+12.8"/>
            <pict yaw="0.0" pitch="+12.9"/>
            <pict yaw="0.0" pitch="+13.0"/>
            <pict yaw="0.0" pitch="+13.1"/>
            <pict yaw="0.0" pitch="+13.2"/>
            <pict yaw="0.0" pitch="+13.3"/>
            <pict yaw="0.0" pitch="+13.4"/>
            <pict yaw="0.0" pitch="+13.5"/>
            <pict yaw="0.0" pitch="+13.6"/>
            <pict yaw="0.0" pitch="+13.7"/>
            <pict yaw="0.0" pitch="+13.8"/>
            <pict yaw="0.0" pitch="+13.9"/>
            <pict yaw="14.0" pitch="0.0"/>
        </shoot>
    </preset>
</papywizard>
Clip Detail
Total Frames: 577
Frames per Second: 30
No processing done to the individual frames. Irfanview is used to resize and crop from 12MB jpeg to 128X720. VirtualDub with Xvid is used to convert to MP4 at 128X720 at bitrate 700 kbps.
Jones
JohnM
by JohnM » Fri Oct 30, 2009 12:19 am
Thanks Jones. Thats helpful.
