presets on the n800
baszslap
presets on the n800
by baszslap » Wed Aug 29, 2012 10:11 am
hi,
is there any way to be completely independent with your n800 when it comes to presets and preset generator?
For now i have to generate my preset in the pc, save it as .xml, copy it on the memory card and load it to papywizard.
I would like to have the generator inside my n800 in order not to carry around my computer
Thx
by mediavets » Wed Aug 29, 2012 11:03 am
What are you using to generate the presets?
baszslap
by baszslap » Wed Aug 29, 2012 11:27 am
I'm usign the preset generators for timelapse (liniar and bezier) and also i want to use the high resolution preset generator for gigapixel panoramas
Thx
