Plugin: OpenDoors
360-compunics-com-ni
Likes: 15 posts
Liked in: 163 posts
Plugin: OpenDoors
by 360-compunics-com-ni » Tue Sep 20, 2016 1:07 am
The new PTP plugin OpenDoors allows to change parts of your pano by displaying distorted hotspots (Open-/Closed-Door-effect). The values needed for calculating the hotspots distorsion settings have to be looked up manually before you can use this plugin.
You need to know the following values for each distorted hotspot image you want to incorprate into your panos:
HFOV (Horizontal field of view), Yaw, Pitch and Roll.
There is a detailed explanation/tutorial in the KRPano-Forum, have a look at this link:
http://krpano.com/forum/wbb/index.php?page=Thread&threadID=7272
Usage:
For every distorted hotspot you want to use add an additional group of settings via the configuration menu.
Fill in the required values: distorted hotspot image path, HFOV, Yaw, Pitch and Roll.
Remember the index number PTP assigns to every group of settings, starting with "0". This index number can be given as the required parameter to the show-, hide- or toggle-actions for the [Plugin] OpenDoors action selector.
That way you can change between different states by assigning the desired action to a hotspot or button.
Hint:
The demotour on my website extends the original KRPano example in that it uses two distorted hotspots, in this case overlaying the same image area (the pool). Of course, you can add different hotspots for different areas of your pano.
The plugin is available for free at: http://dev.compunics.com.ni/
This is free software, enjoy at your own risk.
Required settings for distorted hotspot
Assignment via Pointspot style
Assign the individual distorted hotspot ID
Erik Dreyer likes this post.
gcg1992
Liked in: 4 posts
Re: Plugin: OpenDoors
by gcg1992 » Wed Sep 21, 2016 1:43 am
I downloaded this plugin yesterday but it did not work on my Mac computer:( Would there be an update for Mac users?
Best,
Chenguang
Likes: 15 posts
Liked in: 163 posts
by 360-compunics-com-ni » Wed Sep 21, 2016 2:28 am
there is no specific version for any OS, so if you send me a description of the problem i will have a look at it.
Regards
Michael
gcg1992
Liked in: 4 posts
by gcg1992 » Wed Sep 21, 2016 10:09 am
Sorry, it was my mistake... Now this plugin is in my plugin library and I cannot wait to try it. Thanks a lot!
Chenguang
osamaaf
Liked in: 5 posts
by osamaaf » Fri Oct 06, 2017 2:53 am
Does this work in VR mode?
