Plugin: TourHighlights / TourHighlightsPro
360-compunics-com-ni
Likes: 15 posts
Liked in: 163 posts
by 360-compunics-com-ni » Thu May 19, 2016 2:05 pm
i have released a plugin called "TourHighlights" which is avaliable for free at: http://dev.compunics.com.ni/
Using this PanotourPro plugin you can create an automatic tour visiting all, only the first or a selected list of your panos.
The view movements can be controlled by a specific hotspot style which has to be named "TourHighlightsSpot", and the move properties (zoom, speed and waittime) can be set individually via each hotspot's description.
The site contains a demotour, the menu option "Support" gives access to a ticket system to leave bug reports or any other message.
The plugin has been tested with PTP 2.5.3 on Linux, use at your own risk.
Have a great day,
Michael Brüning
Servicios Compunics
Last edited by 360-compunics-com-ni on Tue Jul 04, 2017 11:45 pm, edited 1 time in total.
2 people like this post.
Likes: 15 posts
Liked in: 163 posts
Re: Plugin: TourHighlights
by 360-compunics-com-ni » Sat May 21, 2016 3:57 pm
The new version 1.1 now contains an endless-loop option, so that it's possible to build an unattended presentation mode tour.
In that case make sure to not activate the startup image which would require manual intervention.
Likes: 15 posts
Liked in: 163 posts
by 360-compunics-com-ni » Sat Aug 06, 2016 4:09 am
The start of the automatic tour presentation can now be assigned to a button or hotspot using the PTP actions selector.
The plugin (file: template.tmpl) also contains a commented 'onTourStart'-event-definition line, so you could activate that to start the automatic presentation without the need of an external event or button setup. In that case, just move the following line (at the top of the file) down two lines, outside the comment section that ends with "{ % endif % }":
<events name="TourHighlightsEvent" keep="true" onTourStart="ShowTourHighlights();" />
Annis likes this post.
Likes: 15 posts
Liked in: 163 posts
by 360-compunics-com-ni » Sun Sep 04, 2016 12:21 am
The procedure to activate the TourHighlights presentation at tourstart was confusing to some users, so i added this as an feature to the plugin configuration settings.
In addition, the current version 1.3 (2016-09-03) can be set to be interruptible by the users, and the actions to be performed when the presentation mode ends can be set via the configuration menu, so that its possible to unhide hotspots or a controlbar, for example.
gcg1992
Liked in: 4 posts
by gcg1992 » Sat Oct 15, 2016 4:58 pm
I am interested in your TourHighlights plugin because I need it to create an auto tour for my project. But I do not understand what do you mean by "Assign a Hotspot-style called 'TourHighlightsSpot' to the hotspots that will form the automatic tour.
The hotspot-image can be an invisible '1x1'-pixel transparent graphic (included in the plugin directory).
Using the hotspot description, you can assign individual move properties for each hotspot as follows:"
Where and what exactly do you mean by hotspot description? Can you make a Youtube video link on how to do that?
Thanks,
Chenguang
Likes: 15 posts
Liked in: 163 posts
by 360-compunics-com-ni » Sat Oct 15, 2016 10:51 pm
this is not plugin-specific, you can find the relevant documentation in the Wiki, e.g.:
http://www.kolor.com/wiki-en/action/view/Panotour_-_Style_tab#Spots_Style
Add a Spot Style to the Project from the Spot Library:
http://youtu.be/qEkpYDacN9Q?t=6s
Enter a Custom Name for the Spot Style:
http://youtu.be/qEkpYDacN9Q?t=11s
Description:
http://www.kolor.com/wiki-en/action/view/Panotour_-_Tour_-_Hotspot_editor_-_Hotspots#Add_Point
Kind regards
gcg1992
Liked in: 4 posts
by gcg1992 » Wed Oct 19, 2016 4:28 pm
Great job! I understand it now... thanks for the plugin and the instructions!
Regards,
Chenguang
janice
by janice » Tue Dec 13, 2016 4:15 am
but my work will only place to jump to the next scene, does not find the point TourHighlights
Likes: 15 posts
Liked in: 163 posts
by 360-compunics-com-ni » Tue Dec 13, 2016 3:57 pm
Last weekend i noticed that my plugin does not work with planar panos, so if you are using planar panos that will be the reason. If however you are using full spherical panos you can PM me a link to your tour or the <prijectname>_skin.xml file and i'll have a look.
freditga
by freditga » Wed Jun 21, 2017 3:07 pm
Thanks for sharing your plugin, it's very handy and pretty easy to use
I have a question about the movement between two spots : would it be possible to smooth it in a more natural way, like accelerating at start from 0 to the chosen speed, and slowing down before stop ?
Fred
Likes: 15 posts
Liked in: 163 posts
by 360-compunics-com-ni » Wed Jun 21, 2017 4:52 pm
yes that's possible. For the free plugin version, you can do that modification by locating the "looktohotspot"-call in the file "tourhighlights.tmpl" and replace the "linear(get(MySPEED))"-option with one of the other motiontypes KRPano offers.
Having said this, i am preparing a commercial "Pro"-version of the plugin, this is one of the additional features that i have implemented. Work will probably be finished until the weekend, so you may have a look at that version too.
Kind regards,
Michael
freditga
by freditga » Wed Jun 21, 2017 7:56 pm
Thank you for the fast response ! I'm going to try that
And I'll take a look at your next Pro version too
Best regards,
Fred
Likes: 15 posts
Liked in: 163 posts
by 360-compunics-com-ni » Tue Jul 04, 2017 11:44 pm
The "Pro"-version of the TourHighlights-plugin is now available.
Unlike the free plugin this „Pro“-version offers a convenient way to select (or unselect) individual panoramas or whole groups for the automatic presentation mode, see below screenshot of the configuration section.
The plugin is "multi-instance-capable", so you can define multiple presentation modes within one tour. See the attached "Feature Comparison List" for the advanced options the "Pro"-version offers in addition.
The price of this plugin is 18€ (including 15% tax), it is available via my website at: http://dev.compunics.com.ni/
Likes: 15 posts
Liked in: 163 posts
Re: Plugin: TourHighlights / TourHighlightsPro
by 360-compunics-com-ni » Wed Aug 16, 2017 2:22 pm
Version 1.1 of TourHighlightsPro has been released, it fixes a bug that prevented the correct assignment of Hotspot-motion-settings.
Current users of this plugin get the updated version for free upon request.
Likes: 15 posts
Liked in: 163 posts
by 360-compunics-com-ni » Thu Aug 24, 2017 4:10 am
Version 1.2 of TourHighlightsPro has been released, it fixes a bug that prevented the correct panorama display order when using the "Select Panos and/or Groups"-selection mode.
As usual, current users of this plugin get the updated version for free upon request.
Likes: 15 posts
Liked in: 163 posts
by 360-compunics-com-ni » Thu Oct 19, 2017 6:10 pm
Version 1.3 of TourHighlightsPro has been released, it fixes a bug that prevented the correct panorama selection when used in "multi-instance-mode", that is, when more than one instance of the plugin was used in a tour.
