Plugin: HotspotsVisited
360-compunics-com-ni
Likes: 15 posts
Liked in: 163 posts
by 360-compunics-com-ni » Thu May 12, 2016 6:59 pm
i have released a plugin called "HotspotsVisited" which is avaliable for free at: http://dev.compunics.com.ni/
Using this PanotourPro plugin you can use a different image for pano hotspots and the floorplan-mapspots pointing to panos already being visited.
The site contains screenshots and a demotour, the menu option "Support" gives access to a ticket system to leave bug reports or any other message.
The plugin has been tested with PTP 2.3 and 2.5.3 on Linux and Windows, use at your own risk.
Have a great day,
Michael Brüning
Servicios Compunics
momocoua
Re: Plugin: HotspotsVisited
by momocoua » Thu Sep 01, 2016 6:27 am
Hello!
Tell me how to make that spot MAP had the opportunity to change the icons and status (active and visit). With the hot spot is no problem though, you can add the button to turn off. And when the mood Panotour Pro program will remove the file index.html record about the script that you are asking to add.
Likes: 15 posts
Liked in: 163 posts
by 360-compunics-com-ni » Thu Sep 01, 2016 3:32 pm
PTP overwrites the index.html-file every time you rebuild your tour, so to have any modification permanent you have to change the HTML Template that is in use, which can be verified on the "Create"-screen.
So its best to copy the default template you are using and modify that copy, for this please find instructions here: http://www.kolor.com/wiki-en/action/view/Panotour_-_Advanced_-_HTML_Templates
momocoua
by momocoua » Thu Sep 01, 2016 3:41 pm
Thank you for the quick response.
How to get to work hotspots in the floorplan prompt.
Likes: 15 posts
Liked in: 163 posts
by 360-compunics-com-ni » Thu Oct 20, 2016 4:01 pm
I was noticed about a bug of the HotspotsVisited plugin when used together with the Little Planet-effect. In this case an additional non-functional hotspots is shown in the center of every panorama. Unfortuantely haven't found a solution for this yet.
Likes: 15 posts
Liked in: 163 posts
by 360-compunics-com-ni » Tue Mar 07, 2017 5:37 pm
A new version 3.0 is available, you can now use different image files for floorplan- and for pano-hotspots.
The required JS-function to update the floorplan spots, which has to be called from "<yourprojectname>.html", is now inserted automatically into the generated html-file, no need to manually add it to your html-template any more.
There are still issues when this plugin is used together with the "Little-Planet-Effect", so i recommend to NOT do that :)
Annis likes this post.
