iPhone/iPad Simulator
DaShan
Likes: 12 posts
Liked in: 6 posts
by DaShan » Sat Dec 26, 2015 4:58 am
It's based 'iPhone/iPad Simulator' of krpano restructuring.
Copy the 'iphone-ipad-simulator.html' to 'My Documents/kolor/PanotourPro 2/html' folder.
When you create a tour, the HTML template chosen 'iphone-ipad-simulator.html'.
Note: I modified the 'iphone-ipad-simulator.html'. I publish this template as a convenience to other users only for PTP, which is released this template do not know whether it is appropriate, if there is any wrong, please delete this post.
Best questions
Dashan
Moderator edit: Download the updated template from the second post.
Cliquetsy likes this post.
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
Re: iPhone/iPad Simulator
by Cliquetsy » Fri Jan 08, 2016 4:01 pm
Cool simulator, handy.
There was an loading error when I tested it. Fixed template is attached to this post.
iphonesimulator.zip
(64.08 KiB) Downloaded 395 times
by Annis » Fri Jan 08, 2016 5:02 pm
Thanks for sharing your template!
It looks useful for quick tests or checks, but it can't simulate everything, so the best iPhone simulator remains the iPhone. =)
I've tested both templates, Cliquetsy's fix works. I'm removing the original template from the OP so that only the fixed template gets downloaded.
DaShan
Likes: 12 posts
Liked in: 6 posts
by DaShan » Sun Jan 10, 2016 6:02 am
Very happy to know that this template useful for everyone and to be perfect. :)
itsrichphoto
Likes: 8 posts
Liked in: 5 posts
by itsrichphoto » Tue Apr 12, 2016 4:58 pm
Thanks for posting
I use the simulator/emulator built into safari. I think Chrome has something similar also.
Go to preferences to get "develop" in the menu. Go to develop then "User Agent". You can select the browser type on different machines to see how the same information is interpreted.
I also sometimes load the xml in safari as this will point out where there are "errors" in the code that will prevent it from working correctly in html5
