Hide/Show specific hotspots inside a tour
Likes: 14 posts
by bdd » Wed Oct 15, 2014 1:18 pm
Many users complain about the fact that in a tour generated by Panotour Pro they can not specify which spots to hide or show, that the only available action hide them all at once.
To be able to group or categorize spots in Panotour Pro interface is a task planned for a future release.
But you can simulate such action by adding your own one managing spot styles as a category of hideable spots.
I wrote this action(s) for a great customer, and you'll find it in the attached archive.
Here is how to use it :
Just open your "User directory" with Panotour Pro menu, and then copy and unzip there the attached archive file.
4 new files should appear in the "actions" subfolder.
Then re-start Panotour Pro.
2 new "advanced" actions should appear in the action chooser widget : "Show Specific Hotspots" and "Hide Specific Hotspots"
Those actions take one parameter : the ID of the spot style you want to show/hide .
This ID cannot be found in Panotour Pro interface.
Just create all your spot styles, use them on some spots, then build the tour.
You'll find the ID of the hotspot styles at the beginning of the "xxx_skin.xml" file.
The ID is the "name" attribute of the "style" XML nodes .
Once a first build of the tour is done, this ID will not change anymore.
It can change from a tour to another, but it will never change in a single tour whatever the number of builds.
So you'll need to open the xxx_skin.xml file only when you will add some spot styles.
hideShowSpecificHotspotsStyleActions.zip
Hide/Show specific hotspots action
(1.64 KiB) Downloaded 702 times
AlbertdeMonaco likes this post.
tianxun0601
Re: Hide/Show specific hotspots inside a tour
by tianxun0601 » Wed Oct 22, 2014 10:57 am
bdd wrote:Many users complain about the fact that in a tour generated by Panotour Pro they can not specify which spots to hide or show, that the only available action hide them all at once.
Hello, bdd:
I've tried the plugin you kindly provided, but have some question...
I check the index_skin.xml and found the spot id is "IconDefaultPointSpotStyle1".
then I went to the "Default Point Spot Style", go to the Advanced and choose "Hide Specific Spot" option
After these, I found the links all disappear. is that normal?
The thing I want to do is as the attached image no 2 shows.
I am confused if this plugin can help to achieve it,
or is there anything wrong?
please help ^^
tianxun0601
by tianxun0601 » Thu Oct 23, 2014 3:40 am
Hi, I've tried this plugin successfully.
Before that, I should create new spot styles by myself, then specify the ID of spot to be hidden.
Now I can click on one spot to control the show/hide of another spot.
I wonder if it is possible to control some spot group to be shown/hidden from the beginning of the tour by just adjusting the url string?
therefore, I can make several sets of tour line in the same krpano project, which can be changed just using different url string.
Could you give me a hint?
Thanks for creating this convenient plugin again.
by benji33 » Thu Oct 23, 2014 9:13 am
If you add an attribute to the querystring as ?hidetypes=TYPE1|TYPE2
You can access this attribute into the krpano script by get(hidetypes)
So you'll have to hide all the TYPE1 and TYPE2 spots on the first init.
So fill the hotspotstyle array used by the hideshowhotspotstylecontent.tmpl file into the top of the startup action with this code, it should works :
copy(mystringforseek, hidetypes);
   loop(mystringforseek != '',
      indexoftxt(mystringsearchindex, get(mystringforseek), '|', 0);
      if(mystringsearchindex GE 0,
         subtxt(mystringpart, get(mystringforseek), 0, get(mystringsearchindex));
         set(hotspotstyle[get(mystringpart)].visible, false);
         set(hotspotstyle[get(mystringpart)].realname, get(mystringpart));
         txtadd(mystringsearchtext, get(mystringpart), '|');
         txtreplace(mystringforseek, get(mystringsearchtext), '');
         set(hotspotstyle[get(mystringforseek)].visible, false);
         set(hotspotstyle[get(mystringforseek)].realname, get(mystringforseek));
         set(mystringforseek, '');
tianxun0601
by tianxun0601 » Wed Jan 14, 2015 9:11 am
Hi BenJi33,
could you please tell me precisely that where should I insert this code into. Could it be the file "hideshowhotspotstylecontent.tmpl" or "index.xml" produced by that Panotour Pro ?
Sorry, I am really new to the plugin editting .... and thanks your kindly reply...
tianxun0601
by tianxun0601 » Wed Jan 14, 2015 9:24 am
Sorry again, I think I've put it in the correct place, it works....!
I put it into the index.xml startup action, and it works,
thanks BenJi for your kindly share^^
tianxun0601
by tianxun0601 » Tue Jan 20, 2015 4:06 am
Execuse me that I would like to ask how to put the below code into the plugin in order to let the code execute automatically and need not to hard code into the index.xml.
because when next time I rebuild the project the code below will disappear again.
thanks for your reply~ ^^
by Destiny » Tue Jan 20, 2015 4:12 am
Hi...
You can add custom xml code into your Custom User Directory. Located in: Documents > Kolor..>>
You will then be able to call it into any new Tour..
tianxun0601
by tianxun0601 » Tue Jan 20, 2015 8:55 am
Sorry , I've found the correct place to put the code , i put it in the hideshowhotspotsstylecontent.tmpl and in the tag
<action name="hideshowhotspotstyleonnewpano">
and it works.....
many thanks.. Destiny....I already did that .... but I am still new to Krpano script so..... hope I can share my success in the future.^^
Alexpopov
Likes: 21 posts
Liked in: 28 posts
by Alexpopov » Sat Apr 04, 2015 7:31 pm
I would like to share the action, that i've created for my needs. It hides or show groups of hotspots by keyword. For buttons use the "Panorama Specific - Toggle button" plugin. Action searchs your keyword in the hotspots style and hide/show them.
For example: in the tour there are
5 point-hotspots with style "hs_red_spot";
5 point-hotspots with style "hs_small_spot";
5 polygon-hotspots with style "hs_door_pol";
5 polygon-hotspots with style "hs_blue_pol"
Add action to Panorama Specific - Toggle button:
to hide all hotspots with style "hs_red_spot" - call action "Hide Hotspots By Keyword" with keyword "red";
to hide all hotspots with style "hs_door_pol" - call action "Hide Hotspots By Keyword" with keyword "door";
to hide all point-hotspots - call action "Hide Hotspots By Keyword" with keyword "spot";
to hide all polygon-hotspots - call action "Hide Hotspots By Keyword" with keyword "pol";
to hide all polygon and point hotspots - call action "Hide Hotspots By Keyword" with keyword "hs";
Action hides/shows hotspots across the tour if use Panorama Specific - Toggle button.
I hope this action will help with big projects. If you improve its code or add some additional options, please post your version here.
Best!
Alexander.
Download the file here
10 people like this post.
panoguy
by panoguy » Sun Oct 04, 2015 8:31 pm
Hi Alexander,
thank you for this great plugin!
Would it be possible to choose a default state in advance,
ie. hide all hotspots with a certain keyword and let the user choose which ones he would like to see during runtime.
Cliquetsy
Likes: 106 posts
Liked in: 119 posts
by Cliquetsy » Sun Oct 04, 2015 9:41 pm
Using the call actions on tour events plugin you could do that, combined with the hide hotspots action.
Using one of the on tour start actions, set the hotspots you want to be hidden.
Alexpopov likes this post.
michael_s
by michael_s » Fri Oct 16, 2015 10:46 am
Hi Alexander,
thanks for the great plugin. Is there any way to hide a group of hotspots by URL in the whole tour?
I've a tour which shows holiday apartments and points of interest.
http://www.berchtesgaden360.de/pano/01.html
But I also need exactly the same tour without the holiday apartments. The holiday apartments then can show the place of their house in the panorama by deep linking. But in this tour all the hotspots of the holiday apartments should be hidden (not just in the deeplinked starting panorama).
http://www.berchtesgaden360.de/pano/01. ... &skipintro
Is there a way to make this work?
Alexpopov
Likes: 21 posts
Liked in: 28 posts
by Alexpopov » Sat Oct 17, 2015 10:47 am
it's possible by adding some code to your build.
Like in previous post by Cliquetsy you need to hide specific hotspots at tour start
Then build tour and add some code to the end of YOURTOURNAME_skin.xml :
<events name="myEvent" keep="true" onTourStart="if(hsdeeplink, alpoShowHotspots(Mykeyword))"/>
Instead Mykeyword use the keyword that you used to hide your hotspots on start tour event. Save this changes.
Now you can add url parameter &hsdeeplink=true to display you hotspots, like this:
http://www.berchtesgaden360.de/pano/01.html?s=pano83&hsdeeplink=true
Cheers!
michael_s
by michael_s » Tue Oct 27, 2015 7:50 pm
Hi Alexander,
thanks for your help. I just tried it and it almost worked. I used the call action "React when the panorama starts, after introduction effects". With this I disabled a group of hotspots in the whole tour. Then I made the changes in the XML and added the URL parameter. And the first panorama shows the hotspots. So far it works. But when I skip to the next panorama or next group the hotspots don't show up.
By default all the hotspots should show up in the tour. So if people share a panorama the hotspots should be displayed. Only if a client wants to hide a group of hotspots, he should have the opportunity the hide it by the URL parameter. But then the hotspots should be hidden in the whole tour, not just the deeplinked starting panorama.
I'm not sure if I made something wrong or if there was a misunderstanding. I hope, there is still a solution.
Alexpopov
Likes: 21 posts
Liked in: 28 posts
by Alexpopov » Tue Oct 27, 2015 8:32 pm
try this instead of previous line of code:
<events name="myEvent" keep="true" onTourStart="if(hsdeeplink, alpoShowHotspots(Mykeyword); set( events[myEvent].onnewscene, if(hsdeeplink, alpoShowHotspots(Mykeyword)) ))" />
I cannot test it, very busy. Let me know how it works.
Best!
Sluhi
by Sluhi » Tue Dec 15, 2015 4:07 pm
I have modified plugin. You can use your hotspot as Toggle button to Show/hide specific Hotspot. Also you can customize duration for Mixer (like Crossfade effect). You can also use with "Call actions on tour events". Can use with original plugin version by Alex Popov in one tour. You can use different setting for different hotspots.
Example: Hotspot 1 (hide/show Hotspot 3 with toggle mode ), Hotspot 2 (hide/show Hotspot 3 with toggle mode and with mixer), Hotspot 3 (only hide Hotspot 3, without effect: toggle mode off, Mixer mode off ).
hs-hotspot-modified.zip
(1.95 KiB) Downloaded 568 times
FunkyPunky
Likes: 10 posts
Liked in: 4 posts
by FunkyPunky » Thu Jan 14, 2016 10:24 pm
Interesting, great Plugin, Alexander!
Is it possible to hide polygon hotspots at tour start but only on mobile/touch devices?
Alexpopov
Likes: 21 posts
Liked in: 28 posts
by Alexpopov » Sat Jan 16, 2016 3:10 pm
With some modifications of this action... You need to call it with device check if(device.mobile, call action)
SebMermoz
by SebMermoz » Fri Jun 10, 2016 2:10 pm
Is there any way to have a button Hide/Show Specific Hotspots directly in the ControlBar ?
Seb
Alexpopov
Likes: 21 posts
Liked in: 28 posts
by Alexpopov » Fri Jun 10, 2016 5:20 pm
Hi, it's possible , but with some xml editing, and it has to be done after every build. You can add show/ hide hotspot action to a Simple button for instance , then in the .._skin.xml copy its onclick action contents to the onclick action of any controll button ( for instance change in controlbar code onclick="setControlModeMoveTo();" change to onclick="alpoHideHotspots(keyword);" ). And remove simple button code (<layer name="button" keep="true" align="center"...../> )
SebMermoz
by SebMermoz » Fri Jun 10, 2016 7:50 pm
thank I'll work on it ! :-)
SebMermoz
by SebMermoz » Tue Jun 14, 2016 2:36 pm
Hi
I tried it,
so that's work to HIDE the specifics hotspot but I canot Show them after.
Have you an idea why ?
thanks
by Annis » Fri Sep 15, 2017 8:20 am
Use the Call Actions on Tour Events plugin and on "react on new panorama after intro effects" assign the action of hiding your hotspots.
http://www.kolor.com/wiki-en/action/vie ... ra_Plugins
