Panotour cannot generated xml file
asandoval
by asandoval » Mon Jun 11, 2012 5:36 pm
I am not able to see the xml file in order to add new plugings to my app. I already tryed uncheck the embed xml files. can someone tell me what can I do.
Regards
by mediavets » Mon Jun 11, 2012 5:40 pm
asandoval wrote:I am not able to see the xml file in order to add new plugings to my app. I already tryed uncheck the embed xml files. can someone tell me what can I do.
Regards
Welcome to the forum...
Are you using a demo/trial version of Panotour Pro?
If you are then you cannot externalise the XML files.
asandoval
by asandoval » Mon Jun 11, 2012 7:45 pm
I am using panotout pro. I have already read the previous post related to this bug, but i am still having the same issue i need that xml file to be able to edit the app.
thanks
by mediavets » Mon Jun 11, 2012 8:24 pm
asandoval wrote:I am using panotout pro. I have already read the previous post related to this bug, but i am still having the same issue i need that xml file to be able to edit the app.
thanks
So are you using a licensed and registered (within the software) version of Panotour Pro?
by gkaefer » Mon Jun 11, 2012 8:43 pm
and if you're using a licensed and registered ptp verwsion, did you disable the "embed" options?
;-) sorry for checking this, but sometimes the most banal is the solution ;-) ... you write you tried to uncheck them... did you or did you not... and if you did, did you than rebuild the tour by deleting all existing/overwriting all existing tour data...
asandoval
by asandoval » Mon Jun 11, 2012 11:41 pm
No worries all tips are valid to me however i did all you mentioned in the post above, I really need modified the app but without the xml it´s impossible. something else. some windows service that not allow me see xml files or whatever. please advise
Likes: 13 posts
Liked in: 115 posts
by bdd » Tue Jun 12, 2012 7:15 am
In Trial mode the XMLs files are always embedded into the krpano flash player.
Once you register Panotour Pro with a valid license, you will be able to not embed them.
by gkaefer » Tue Jun 12, 2012 10:53 am
asandoval wrote:No worries all tips are valid to me however i did all you mentioned in the post above, I really need modified the app but without the xml it´s impossible. something else. some windows service that not allow me see xml files or whatever. please advise
start panotour pro 1.8.0 (I asume the 64bit Version Windows...)
Under Help you've 2 options:
HELP->About
HELP -> Licenses
give us one or both screenshots...(showing us if you're using the demo or a registered panotour pro version)
the demo version is limited. exported tours are always embedded ones... demo tours can be viewed only offline and the tour does show a watermark in demo mode.
take care you do not mix you autopano and you panotour licenses...
like in my screenshot...
open ptp and open your project or create one
ad 1. click on one pano on left screen
ad 2. choose project properties
ad 3. change to Tour build
ad 4. show that standard is enabled and mobile device Tour DISABLED
ad 5. choose a HTML template and enable/disable the embed options - in your case it should look like in my screenshot to disable the embedding...
6. save your project
7. finally use "Build tour as..." in combination with "delete all existing files before saving"
and finally make sure that your windows explorer is showing the .xml files
make yure you dont save your files and dont export your tour to the root directory of your harddisc. windows often treats this root dir as hidden and does not display all files...
Liebe Gruesse,
