sound on iphone
zebragruen
sound on iphone
by zebragruen » Fri Feb 18, 2011 11:08 am
I use ptp 1.5
I created a testpanorama:
www.virtuelle-ansicht.de/test/flash.7z
The pano runs but the sound-link in it doesn't.
why??
regards
Alex
by gkaefer » Fri Feb 18, 2011 12:07 pm
Hi Alex,
have a look here:
http://www.krpano.com/forum/wbb/index.php?page=Thread&threadID=3975&pageNo=1&highlight=iphone+sound+link
I did not read all, it seems that "sound" and "sound interface" were first unsupported, later Klaus did reply in #14 that its implemented now and he posted some details & restrictions....
(sorry no experience here, can only point to the thread ;-)
PS: in your 7z file the iphone license is implemented!!!! I would not publish this... everybody can (mis)use it....
Liebe Gruesse,
zebragruen
by zebragruen » Fri Feb 18, 2011 12:20 pm
thanks!
killed the zip and read the quatiation!!
zebragruen
by zebragruen » Fri Feb 18, 2011 12:47 pm
Read the quotations and still have no idea how tho solve the problem.
Question: Does PTP 1.5 support sound for Ipod?
Regards,
Alex
Liked in: 227 posts
by Destiny » Wed Mar 30, 2011 9:28 am
Hello Alex... I have done extensive testing of both audio and video in a pano for iDevices using the kolor software... In a nut shell, you cannot play either within the pano directly... If you want to play Audio, you can put a link on a hot spot which will open a new window in your iPhone and it plays fine.. You are still restricted however in which formate and codec you use... You can use MP3 or AIFF format with HE-AAC and MP3 codec..
D
