Borrego Badlands at Dusk
Montrez nous vos oeuvres !
ckiely
by ckiely » Tue Jan 17, 2006 4:56 am
Fuji S3 Pro
Nikon 50mm (prime)
f22, 1/6
27 source images
2-Stop Soft ND Grad used on top row
Anza-Borrego Desert State Park (California)
15-JAN-2006
Looking out from Font's Point into Rainbow Wash and Hills of the Moon Wash in the Borrego Badlands.
by AlexandreJ » Tue Jan 17, 2006 11:13 am
What a beautiful landscape. The ground is really interesting with this kind of light.
timpdx
by timpdx » Tue Jan 17, 2006 5:21 pm
Wow, there must be an amazing amount of detail in there. Too bad the jpeg compression is killing this. Nice choice on the time of day, too.
francois.simond
by francois.simond » Tue Jan 24, 2006 12:21 am
With 27 sources images, the level of details probably equals these outstanding perspective and lights.
François Simond
by GURL » Tue Jan 24, 2006 2:31 pm
About Timpdx's Pacific Coast Highway, Ckiely wrote:I'm actually pretty amazed that the right side of the frame actually found some matching points. The pity is that you are pretty much forced to use a wide angle to get these, if you use a "normal" e.g. 50mm you're shooting unmatchable blue sky or moving clouds.
I suppose your Borrego Badlands pano is a 5 x 5 pano (...or about, I'm embarrassed as 27 is a prime number!) and you say it was shot using a 50 mm lens. The topmost row (sky with not any crisp feature) looks more difficult to stitch than the bottom right part of Tim's pano (sea Waves, long shutter times.)
For panos like Tim's one (single row) I would use an accurately leveled tripod.
For such a large sky part like in your multi-row pano, I'm afraid this would not be enough...
(By the way, these are two beautiful panos!)
ckiely
by ckiely » Tue Jan 31, 2006 4:56 am
Not sure if there's a question there. But it is cropped quite a bit... I typically shoot a little more in the bottom as there is a tendency for the corners to get stretched so I give myself a bit more to play with. So it was probably about a 5x5 w/ two more on the bottom or something like that.
Since digital is "free" I typically shoot a lot more than I really need so I am well covered. Compositionally I probably choose the right 2/3s of the images as my final output.
I shot the sky row w/ just a touch of land on the horizon.
ckiely
by ckiely » Sun Feb 12, 2006 9:01 am
FYI I've printed this image horrifically large, 30" x 45" (76cm x 114cm). To put things in perspective, it is nearly the size of a car windshield.
I am speachless at the detail included. Thanks for the development guys! :)
by AlexandreJ » Sun Feb 12, 2006 9:05 am
I think you made an error in conversion, as 762cm x 1143cm, it's the size of a 3 stock building ...
30" x 45" is 76,2 cm x 114,3 cm.
Anyway, it must be something to see.
ckiely
by ckiely » Sun Feb 12, 2006 9:14 am
Yes, corrected, thanks.
