Very good resolution
Montrez nous vos oeuvres !
by klausesser » Tue May 21, 2013 11:18 am
teddy wrote:With what Fisheye obiective are made this photos?
You can us any lens for that. A fisheye does it with fewer shots - any fisheye. That´s the only difference: the amount of shots.
On a FX camera it´s usally 15mm or 16mm fullframe-fisheye or 10,5mm or 8mm circular fisheye.
On a DX camera it´s usually 10,5mm fullframe-fisheye or 8 mm or shorter circular.
But you also can use a non-fisheye - just need to make more shots. The advantage of making more shot with a non-fisheye is
to get higher resolution.
See it here: Canon 5D2, Nikon 35mm lens, 45 shots - http://www.360impressions.de/Klapheck/ use the zoom.
Using the 35mm you get 35000px width which means around 700mpx doing 45 shots.
Using a 15mm fisheye you get 16000px width 120mpx which means around 120mpx doing 6 shots.
That means the fisheye shots don´t provide such a deep zoom-range.
The key to all this is a very precise NPP-alignment - most important for indoor shootings.
Christian Stüben
Likes: 3 posts
Liked in: 9 posts
by Christian Stüben » Tue May 21, 2013 2:34 pm
Maybe i am wrong, but in my opinion these panos are not made by fisheye. The resolution is much to high, you can zoom in deeply. They must be made with some longer focal length.
greetings from germany
Chris
by klausesser » Tue May 21, 2013 3:23 pm
Christian Stüben wrote:The resolution is much to high, you can zoom in deeply.
Not so much. Theoretically it might be a D800 and s fisheye.
With a 35mm lens the resolution would be higher and the zoom-range wider. So it could be 20mm rect. on 21mpx or so.
We can only guess.
Doesn´t matter at all in the end whether it´s fisheye or not. Such shots can be done with almost every lens under 50mm (because of DOF).
teddy
by teddy » Thu May 23, 2013 7:56 am
@klausesser
Tks. for your informations.
You say that it is possible to make a panorama with a non-fisheye ?
With a fish-eye I take 6 shoots + 2 for floor and 1 for top.
This mean: 60 degress by shots.
With a camera 18-55 mm non-fisheye, at what degree must take the shots?
by klausesser » Thu May 23, 2013 10:39 am
teddy wrote:@klausesser
Depends on what focal length you choose in the 18-55mm range and also depends on your sensor-size.
Which head do you use? Which camera?
teddy
by teddy » Thu May 23, 2013 11:40 am
Nikon 5100 +Nodal Ninja III
Teddy
teddy
by teddy » Thu May 23, 2013 12:11 pm
In case that use a non-eyes objectives, the shots must be convert for spherical phanoramas?
by klausesser » Thu May 23, 2013 1:59 pm
teddy wrote:In case that use a non-eyes objectives, the shots must be convert for spherical phanoramas?
??? sorry?
bst, Klaus
teddy
by teddy » Thu May 23, 2013 2:13 pm
If made shots with a non-fisheye(normal lens), PTGUI don't make a equirectangular panorama. Done a flat panorama.
