Infrared panos at Bushfield Camp, near Winchester
Montrez nous vos oeuvres !
karma mechanic
by karma mechanic » Tue May 07, 2013 1:10 pm
At first glance, even in normal light, you might think that Bushfield Camp is actually near Chernobyl. The Army left the site in the 1970's and it has quietly fallen apart since then.
In infrared it is even more desolate.
UK Pano
by UK Pano » Fri May 10, 2013 12:48 pm
that is cool and does look post-apocalypse-esque!
karma mechanic
by karma mechanic » Fri May 10, 2013 8:14 pm
One more...
(I like post-apocalypse-esque, whether it is a word or not, that's exactly what these are)
Last edited by karma mechanic on Fri May 10, 2013 8:15 pm, edited 1 time in total.
ygilquin
by ygilquin » Wed May 15, 2013 12:58 pm
Gorgeous IR pano !! Well done.
Yann G.
www.kolor.com
teddy
by teddy » Thu May 23, 2013 1:53 pm
Do you use a fisheye or a non-fisheye objective?
karma mechanic
by karma mechanic » Thu May 23, 2013 9:54 pm
teddy wrote:Hi,
All my panos use a Samyang 8mm vertically on a Pentax K-7. That lens works extremely well in IR once allowance is made for the different focus of IR wavelengths. That was adjusted by loosening the focus ring and setting it so that infinity on the ring matched what the sensor sees. Then focus is largely done by looking at the subject and setting the ring to (say) 3m or so.
Previously I used the Sigma 10-20mm, but that tends to have poor contrast in IR due to some internal reflections. (That's because some surfaces that are black in visible light are actually metallic looking in IR - but I digress...)
