Private apartment HDRi
Montrez nous vos oeuvres !
Variety
by Variety » Sat Mar 09, 2013 6:19 pm
Greetings from Moscow!
http://www.hdrl.ru/files/360/13/build/virtualtour.html
Nikon D800 + Nikon 17-35mm f/2.8D ED-IF
There will be 12 scenes.
Thank you for your attention.
Liked in: 227 posts
by Destiny » Sat Mar 09, 2013 7:13 pm
Hi..
Sorry, I have to be honest... Yuck, says it all.. Not the pano but rather your choice of HDR effect.... Try using Photomatix with Fusion/Realistic which would be LDR. Its the Blacks I do not like... I try to keep my ISO down to 100 with my D800 for in doors to avoide Photomatix picking up on the noise when using a high ISO... If I had more RAM in my iMac, I would be using my 35mm Prime but even though I know its shaper then a fisheye, my iMac will not coup iwth the image size... Great gear you have; I am using my D800 with 14/24 and my NN4. I will use the Fusion/Realistic when I get to process them in a couple more weeks...
Destiny.....
Variety
by Variety » Sat Mar 09, 2013 8:13 pm
Thank you for your feedback. This is not the final version. I will use your advice. Thank you.
Variety
by Variety » Sat Mar 09, 2013 10:07 pm
Variety
by Variety » Sat Mar 09, 2013 10:40 pm
Variety
by Variety » Sun Mar 10, 2013 12:06 am
Variety
by Variety » Sun Mar 10, 2013 4:28 pm
Without retouching. Fusion/Realistic.
Сomparison - http://www.hdrl.ru/kolor/build/virtualtour.html
UK Pano
by UK Pano » Mon Mar 11, 2013 12:28 pm
what's with the music??
Variety
by Variety » Mon Mar 11, 2013 2:53 pm
Сomparison - http://www.hdrl.ru/files/360/16/build/virtualtour.html
P.S. FRANK SINATRA
Liked in: 227 posts
by Destiny » Mon Mar 11, 2013 10:14 pm
Hi
May I ask what EVs did you use and how many bracketed shots... Your lights seem to be blown and your blacks are noisy. It also looks like you used a very high ISO setting..This would account for the blacks... Also, did you capture using RAW....
UK Pano
by UK Pano » Wed Mar 13, 2013 11:49 am
Variety wrote:P.S. FRANK SINATRA
Question was more to do with it's relevance to the pano - why does the pano need music?
Variety
by Variety » Wed Mar 13, 2013 7:40 pm
Destiny wrote:Hi
I was shooting with ISO 100. I found an error in EVs. Three-shot bracketing. Thanks for your important comments and recommendations.
Variety
by Variety » Wed Mar 13, 2013 7:41 pm
Music in interior panoramas is a good addition for comfortable viewing.
by gkaefer » Wed Mar 13, 2013 8:42 pm
yes but what you did not considered is that per Default the Sound volume is set to 100%.
I've a PC-Standard 5.1 soundsystem with 100W Subwoofers... and entereing Sound enabled pano-tours (not only yours) results in a massive shock and the hasty search Begins to find the switchoff button...
so you did no use ptp 1.8 with no Sound control builtin Options... you used krpano, so please think about editing the XML files to Switch Sound volume to 50% or build a volumecontrol so users can choose their personal taste soundlevel....
Variety
by Variety » Fri Mar 15, 2013 3:25 pm
gkaefer wrote:
Variety wrote:
UK Pano wrote:Question was more to do with it's relevance to the pano - why does the pano need music?
I couldn't have envisioned such a problem - my computer is connected with a HDMI cable to an external processor, where the volume is limited. Of course, if the sound goes through the analog channel from the sound card - I can imagine this nightmare!
I fixed it - lowered the volume on all of my works. Thank you! This is what the forum is for, else I woudln't have learned about this problem.
