set size of content in webcontent spot
bonapictura
Liked in: 4 posts
by bonapictura » Wed Jan 10, 2018 11:04 am
Currently the size of the content in a webcontent spot is automatically set to the dimensions of the spot.
In most cases this results in a very low resolution of the content. See this topic: http://www.kolor.com/forum/viewtopic.php?f=92&t=37556&p=204870#p204870
At the moment the webcontent spot style has no options at all to change this so you have to edit the xml. This is annoying because you have to remember to make these changes everytime when you make a change in the tour and create a new build.
Ideally in the webcontentspot style you should be able to set your own default size for the content.
I assume this is an easy thing to implement so I would like to see this in a next version of panotour pro.
bonapictura
Liked in: 4 posts
Re: set size of content in webcontent spot
by bonapictura » Wed Jan 10, 2018 11:16 am
I think the best implementation would be if you could set the horizontal resolution of the content and have the vertical resolution calculated in ratio of the spot dimensions.
i.e. in the spot style parameters you set the contentwidth to 1000
Then when you create a webcontent spot which is 280 x 170 then the calculated contentheight would be:
contentheight = contentwidth / spotwidth * spotheight = 1000 / 280 * 170 = 607
