Google Street View panoramas
mjaszo
Liked in: 3 posts
by mjaszo » Fri Feb 26, 2016 5:53 pm
Could you add the option of using Google Street View panos? I'm shooting Google virtual tours and what it lacks the most is navigating between huge amiunt of panos. Try this example, it has 389 panos and only levels number and arrows to navigate. This example has 1200 (as far as I know, not mine) but thanks to simple menu it's far easier to jump between areas: http://www.royalcaribbean.co.uk/google- ... uise-ship/
There are add-ons like TourMake https://www.tourmake.it/, TourDash http://tourdash.com/ and View3 https://vtc.view3.com but why not having that in PTP?
Cheers!
Christian Stüben
Likes: 3 posts
Liked in: 9 posts
Re: Google Street View panoramas
by Christian Stüben » Mon Feb 29, 2016 2:02 pm
If you don´t like the existing add-ons, why don´t you make your own via html and css? Have a look:
http://360.haifischbar.de/panoramen/beispiele/unihalleNAVI.html
And mixing panotour with street view trusted is possible too:
http://360.haifischbar.de/panoramen/beispiele/appartmenthaus_am_hochfirstwegNAVI.html
greetings from germany
Chris
mjaszo
Liked in: 3 posts
by mjaszo » Mon Feb 29, 2016 2:23 pm
Does asking for additional features mean not liking what's available? What's the point of talking about "PTP future" then?
A lot of add-ons can be done with changing the code and using html/scc/js etc. But the whole beauty is to have it all in PTP, isn't it?
I'll check your links. Thanks.
mjaszo
Liked in: 3 posts
by mjaszo » Mon Feb 29, 2016 2:52 pm
Very cool examples - that's exactly what we need in PTP.
The add-ons are more or less ok, it's just the cost of using them I don' like. For View3 it's 100E license + 200E per virtual tour. Both probably per year. PTP is 400E.
View3 example: https://vtc.view3.com/pl/vt/Biblioteka
