Breakpoints
Xander Berkenhagen
Liked in: 8 posts
Breakpoints
by Xander Berkenhagen » Sat Nov 14, 2015 4:44 am
Would it be possible to add breakpoints to ptp?
then we could optimize for mobile and desktop the right way..
Regards,
Xander
Re: Breakpoints
by benji33 » Wed Nov 18, 2015 11:03 am
How do you imagine this feature please ? How would you integrate or use it in existing plugins?
Xander Berkenhagen
Liked in: 8 posts
Re: Breakpoints
by Xander Berkenhagen » Thu Nov 19, 2015 3:23 am
I would add a list to the relevant plugins and spots.
At start the list is not active and the plugin or spot works the same on every resolution.
Then you can add a breakpoint to the list, automatically it copies all the settings from the plugin to that breakpoint.
If you wanna change the settings at a certain breakpoint you can select it. If none is selected it has the global values.
This way it is possible to have a large map on a big monitor, a smaller map on another position on a tablet. And maybe no map on a mobile...
This way you have total control over the plugins at every configuration. (Even colors, size, location, active yes/no).
Hope you like this idea..
Re: Breakpoints
by benji33 » Thu Nov 19, 2015 10:22 am
Ok I understand. Thanks for the report.
