Yaw plugin
Xander Berkenhagen
Liked in: 8 posts
Yaw plugin
by Xander Berkenhagen » Thu Oct 29, 2015 2:00 am
Hi guys,
I noticed the Fov Toggle plugin in 2.5b4.
Is it possible you guys also create a Yaw toggle plugin?
But please with the possibility to also have an action if the yaw is between two values..
Like do action if yaw is between 40 and 45 degrees.
Regards,
Xander
Re: Yaw plugin
by benji33 » Thu Oct 29, 2015 10:39 am
For Yaw or Pitch it's a little different due to the full spherical, partial or flat panoramas format.
So a Yaw value can be totally false on a partial panorama for instance.
For fov it's more simple even if the Fov is never reached.
Note : be carreful with this kind of plugin if you change the projection ! Little planet has a 150° or more fov for instance.
Xander Berkenhagen
Liked in: 8 posts
Re: Yaw plugin
by Xander Berkenhagen » Thu Oct 29, 2015 11:31 am
But can this be developed for a future release?
Maybe only for full 360 pano's.
Cause then it would be possible to popup messages when people look at a certain part of the pano...
Ot would make tours more interactive.
Regards,
Xander
