Google Streetview
Deckg
Google Streetview
by Deckg » Sun Jan 18, 2015 11:29 pm
Would it be possible in the future to be able to add locations from Google Streetview as a scene?
This would be a great way to mix and match locations and would open up a whole new market too.
Re: Google Streetview
by Destiny » Sun Jan 18, 2015 11:49 pm
Hi.. I guess you could do this now.. Just add the street view to a website box set at 100% with no frame.. over a dummy pano.. Use Auto Open a Website Box to view it.. You will have to use a Thumb navigation or a Next Pano on the menu, making sure the menu zorder is above the Website Box.. There would be a transition of the Website Box opening but I am sure that can be turned off... The only think I do not know, wether the Street View can open automatically or its a user input..
by benji33 » Tue Jan 20, 2015 9:58 am
Impossible from GUI at this time due to the internet needed access to serve the StreetView panorama.
Panotour is not designed yet to do it.
Workaround solutions like Destiny's one are the way at this time.
