Request TMPL script for Cursor   [DONE] - View the solution
by Destiny » Sun Jan 04, 2015 12:34 pm
Hi.. I request a TMPL script be created for the cursor..
Re: Request TMPL script for Cursor
by benji33 » Mon Jan 05, 2015 9:36 am
For cursor icon (with or without animation) changes ?
by Destiny » Mon Jan 05, 2015 11:00 am
Well, Benjamin.. To have a Cursor just as a single graphic Mouse Follow would be ok'ish for a start and to be honest the cursor code doe not work too well with Safari, not sure about other Browsers since the all seems to have gone silly these days as if fighting some kind of war.
Its often the case with me that the default cursor is visible with the new cursor until mouse leaves the pano area and returns, after which its then just the new cursor. Also when leaving the pano to go to the Safari menu, the cursor can totally disappear.
I would say both to please everyone... Animated is good too, but when I refer to animation I mean a transition on move as in 8way or 4way etc.. Not an actual animation as in the krpano flash option animation.. I remember having animated cursor for Adobe Director was a pain, but that worked as a sequence of images with the effect created by code, as in PTP current hotspots...
I think if a basic start could be added to the Plugins, keeping it simple it would be good..
Re: Request TMPL script for Cursor  [DONE]
by benji33 » Mon Jan 05, 2015 11:02 am
A task is opened on our side for custom cursors, yes. But not treated yet. I add your comments ;)
by Destiny » Mon Jan 05, 2015 12:38 pm
=D =D
