Panorama Mega Menu
Vil Muhametshin
Panorama Mega Menu
by Vil Muhametshin » Thu Oct 02, 2014 10:39 am
Would be great to expand the Panorama Menu plugin a bit. There could be an option to add columns (for vertical) and rows (for horizontal) if we use THUMBNAILS. With max panorama number in column or row.
Also the title could be limited (as an option) with the thumbnail size, if you place it above or below the thumbnail. Now the menu looks quite strange if some of panorama titles are much longer than others.
If the title is longer than thumbnail, it would show full only on mouse over - as a layer over the thumbnail, for example. The same way title could show up, if initially we see only thumbnails without titles.
BR,
Vil
Re: Panorama Mega Menu
by mediavets » Sun Oct 26, 2014 7:33 pm
Vil Muhametshin wrote:Would be great to expand the Panorama Menu plugin a bit. There could be an option to add columns (for vertical) and rows (for horizontal) if we use THUMBNAILS. With max panorama number in column or row.
Vil
The Thumbnails stack plugin more or less does that now?
