Whish list
timographie
Whish list
by timographie » Thu Sep 11, 2014 8:25 pm
Some quick ideas while using PanoTour 2 which I would love to discover for future versions.
1- Show/Hide controls option:
Integration of differents buttons to hide/show differents menu.
1st "show/hide" button for the 1st group of graphics elements.
1nd "show/hide" button for a 2nd group of graphics elements.
etc..
2- Gallery plugin :
Integration of a SINGLE button which can open the gallery on a specific image depending of the panoramic which is playing.
3- Show a picture option :
Add the "Show overlay" option behind a picture.
4- Fade option between 2 panoramas (night/day) :
Integration of a SINGLE button which can fade two 360's taken at the same spot at differents time (night/day) by keeping the same framing.
5- Splash screen option :
Add actions possibilities on virtual tour introduction, maybe with layer's options.
1st layer 5 sec - 2nd layer 5 to 10 sec etc...
Some small details which can allows to create new great featured options inside virtual tours
Thanks to all Kolor Team
Re: Whish list
by mediavets » Thu Sep 11, 2014 8:49 pm
timographie wrote:2- Gallery plugin :
The Notifications plug-in can be used to create pano-specific buttons:
http://dev.alexpopov.me/panotour_plugin ... BH8rxYXMyg
timographie
Re: Whish list
by timographie » Fri Sep 12, 2014 12:01 am
Very interesting plug-in
Thank's for the information
timographie
Re: Whish list
by timographie » Fri Sep 12, 2014 12:10 am
I saw that you also developed "the Start screen" plugin
http://dev.alexpopov.me/panotour_plugin ... BIp-i5_voE
which exactly answer to another wish I exposed, and far much better than I thought
It seems that christmas is earlier this year!
Very nice work
marzipano
Liked in: 14 posts
Re: Whish list
by marzipano » Mon Sep 15, 2014 7:00 pm
When autorotation is used on a non-360 degree panorama it starts up slowly and gradually builds up to the f/s specified in the parameters. However, it doesn't slow down gradually when it reaches the other end - it just stops dead
Can it be made to slow down gradually at the same rate it speeds up ?
Re: Whish list
by mediavets » Mon Sep 15, 2014 7:04 pm
marzipano wrote:When autorotation is used on a non-360 degree panorama it starts up slowly and gradually builds up to the f/s specified in the parameters. However, it doesn't slow down gradually when it reaches the other end - it just stops dead
Autorotation (autotour also) doesn't work very smoothly with partial panos, a known issue I believe.
