Live-Pano enhancements
Hellkeeper
by Hellkeeper » Mon Aug 04, 2014 11:13 am
I think the usability for the Live-Pano Function could be a bit enhanced.
What I noticed:
- When setting the Video Crop - it would be very handy if I could zoom the Picture out. (Now it's fixed in full size)
- When I modify the Crop-Mask - it will scale symetric - and I can't move it ... better would be if I could modify it free for every side of the mask
- When I create the Blending-Mask - it would be great if I could play the Video Frame by Frame ... so I can see where the Subject in the Video is moving to ... otherwise it's very hard to set the Blending Mask correct ... (otherwise --> cut off Parts of Video & redoing everything over and over)
Would be great if some of those ideas get into APT soon! ;-)
Bye from Austria
Andreas Schnederle-Wagner
Liked in: 227 posts
Re: Live-Pano
by Destiny » Mon Aug 04, 2014 11:20 am
Agreed...
Destiny.
futureweb
Re: Live-Pano enhancements
by futureweb » Mon Aug 04, 2014 3:53 pm
It would also be nice if you could edit your mask afterward, so you dont have to start from scratch everytime you make a little mistake..
Other than that I noticed a little Bug:
If you want to include a second Livepano-video, the video-crop Window displays the image of the first video you included. If you continue to the mask-window it displays the correct image..
toto-foto
by toto-foto » Fri Aug 08, 2014 1:15 pm
There is a very small area for drawing mask... at the same time there is a huge useless space up and down the user interface window...
