Target transition freezes livepano video.
furmanczak.com
Liked in: 3 posts
by furmanczak.com » Wed Jul 09, 2014 9:38 pm
Target transition with "custom view to panorama view" with livepano firstly shows panorama then play livepano video(s).
Is there possibility to change it? It looks unnatural.
It could be great if panorama were loaded, video played and then for example "Custom view to panorama view" were showed (I'm talking about the move at the beginning that presents us panorama).
(the same about pictures with parallax)
Regards Filip
Likes: 13 posts
Liked in: 115 posts
Re: Target transition freezes livepano video.
by bdd » Thu Jul 10, 2014 9:35 am
furmanczak.com wrote:Target transition with "custom view to panorama view" with livepano firstly shows panorama then play livepano video(s).
Regards Filip
Actions that do a move in krpano blocks other actions.
The video should be displayed as soon as it is ready and in your case as soon as the XML description of the scene is loaded.
But as their is a move with the transition thos basic events are not called.
So yo can try a "delayed transition" that will do the job.
The move is delayed to next frame.
Copy the attached file into the "transitions" subdirectory of your user directory (with the menu Edit/Open user directory)
And restart PTP
A new transition will appear called "Delayed custom view to panorama view"
DelayedCustomViewToPanoView.xml
(499 Bytes) Downloaded 50 times
