Exclude pano's from menu   [SOLVED] - View the solution
Xander Berkenhagen
Likes: 4 posts
Liked in: 8 posts
by Xander Berkenhagen » Tue May 27, 2014 11:21 pm
Hi Guys,
I would like to have an option to exclude certain pano's from the menu / sub menu.
Is that possible.
Regards,
Xander
Re: Exclude pano's from menu
by mediavets » Tue May 27, 2014 11:48 pm
Xander Berkenhagen wrote:Hi Guys,
So would I.
Is that possible.
Regards,
Xander
Not via the GUI currently.
Likes: 13 posts
Liked in: 112 posts
Re: Exclude pano's from menu  [SOLVED]
by bdd » Tue Jun 03, 2014 2:14 pm
So would I.
But it can be easily done by modifying the generated code of the Panorama Menu.
Just open the xxx_skin.xml file, and fine the "Panorama Menu" comment.
Then you'll see how each menu item is described.
Just remove the items you do not want to see.
Xander Berkenhagen
Likes: 4 posts
Liked in: 8 posts
by Xander Berkenhagen » Thu Dec 04, 2014 8:47 am
Can this be added to the gui?
Likes: 82 posts
Liked in: 184 posts
by benji33 » Fri Dec 05, 2014 10:46 am
Feature request already reported.
