Last used folder
ERR
Likes: 4 posts
Liked in: 23 posts
Last used folder
by ERR » Sat May 24, 2014 1:46 pm
I think it's fair to say that most of us designing tours use a logical structure and keep related tour files in the same folder with subfolders.
When I reference multiple files for a specific tour (pdf, image, video...). every time I "insert" a file I have to drill down from the "Kolor/Panotour Pro" folder" which is a huge waste of time in a workflow.
What I would like to see in an "update" is when I initially use a file in a tour, I want to be brought back to that specific folder the next time I need a file. Not have to drill down from the default "Kolor" folder.
I am new to this software so if I am missing a setting in the preferences please let me know.
Thank you,
Ed
The sun will come out, tomorrow... Well if not tomorrow then at least in 4 years and if not 4 years then most definitely 8 years max. But hopefully in 1 year or less.
Likes: 13 posts
Liked in: 115 posts
Re: Last used folder
by bdd » Mon May 26, 2014 8:12 am
ERR wrote:I think it's fair to say that most of us designing tours use a logical structure and keep related tour files in the same folder with subfolders.
Thank you,
Ed
Strange.
Last folder should be kept and proposed when you want to select a new file.
On which kind of OS are you running?
Are your files on a local disk or on a network one ?
Evgeniy Listyuk
by Evgeniy Listyuk » Thu Jul 31, 2014 10:47 am
Oh, Yes! Long ago wanted to write about this! I do this a lot when exporting panoramas or faces of the cube. I use WINDOWS 7 64x
ERR
Likes: 4 posts
Liked in: 23 posts
by ERR » Thu Jul 31, 2014 6:31 pm
Thank you,
Ed
Strange.
Sorry, never got back to this one....Work :/
Windows 7 pro 64bit. Local disk.
Peace,
Ed
