Reusable custom polygon (settings + data)
gadonz
by gadonz » Tue Jan 21, 2014 11:05 am
Say I set up a custom polygon spot which triggers an audio snippet and a web box. I add an audio file <a> and an address <url> for the web box.
The polygon is overlaid on a fire alarm in one of my panoramas. This panorama is part of a tour with 20 locations in each of which there is a fire alarm. I want to create a polygon spot on each instance of the fire alarm in the different panos of the tour but would like to use the same exact audio snippet <a> and same exact web address <url> data.
At the moment it seems that I can save the custom polygon with audio snippet and web box actions, but not data, i.e. I can’t save the audio snippet <a> and <url> for the web box to re-use – I have to copy/paste <a> and <url> each time.
It would be great if I could save an instance of the custom polygon plus <a> and <url> data.
Re: Reusable custom polygon (settings + data)
by benji33 » Thu Jan 23, 2014 11:21 am
Normally it should be corrected. I'll add a review task to verify if it's done.
gadonz
by gadonz » Thu Jan 23, 2014 11:46 am
I don't think I was clear enough in my request. What I'd like to be able to do is this: set up a custom polygon once with e.g. audio saying "This fire alarm is connected to a monitored system..." and a url that points to <www.company.com/firealarm> and use it in multiple locations of the tour without having to enter the text and url each time. Hope this clarifies.
by benji33 » Thu Jan 23, 2014 3:14 pm
You set url + text + others actions into STYLE window ? into Panotour Pro 2.0 RC 2 ?
If yes it should be working to use this spot style on each generated polygon.
gadonz
by gadonz » Fri Jan 24, 2014 1:24 pm
Of course! Thanks. Sorry for the confusion.
