Directional audio + directional text description
gadonz
by gadonz » Tue Jan 21, 2014 10:13 am
I’ve set up a custom polygon spot which triggers an audio snippet and a text description. In the built tour, when rotating away from the audio source, directional sound kicks in and the audio fades away, as expected. It would be great if the associated text description would fade in sync with the audio, i.e. the same sliding percentage for volume would be applied to the text opacity.
Re: Directional audio + directional text description
by benji33 » Thu Jan 23, 2014 11:28 am
Not an easy way to do it. But I add your report into the possible feature requests.
At this time directional is only supported by the flash player.
gadonz
by gadonz » Thu Jan 23, 2014 11:39 am
Thanks, Benjamin.
