Combining cropped Flash and multiresolution HTML5?
John360
by John360 » Tue Jan 14, 2014 11:48 pm
I have not found a way of combining multires HTML5 ( full sphere needed? ) and nadir cropped Flash.
Is it possible?
Re: Combining cropped Flash and multiresolution HTML5?
by mediavets » Wed Jan 15, 2014 9:33 am
John360 wrote:I have not found a way of combining multires HTML5 ( full sphere needed? ) and nadir cropped Flash.
Is it possible?
HTML5 multi-res. only works with pano images with a pano FOV of 360x180.
by benji33 » Wed Jan 15, 2014 11:33 am
Once cropped you are into a partial spherical panorama.
So HTML5 multires is not available yet (but will be one day) due to the amount of unused tiles because the player display the sphere into a full cube (360x180).
Panotour can do it but it's not offered into UI due to the amount of unused tiles generated.
John360
by John360 » Wed Jan 15, 2014 1:53 pm
So I thought, but I did some testing putting a nadir cap on and also using crop and multiresolution setting. The build seemed to be multiresolution, but I tested on small panoramas 16000*8000.
by mediavets » Wed Jan 15, 2014 2:01 pm
John360 wrote:So I thought, but I did some testing putting a nadir cap on and also using crop and multiresolution setting. The build seemed to be multiresolution, but I tested on small panoramas 16000*8000.
If your pano image has a pano FOV of 360x180, and then you use the PTP Hotspot editor Crop tool, then I think multi-res. HTML5 will work.
The Hotspot editor Crop tool does not physically crop the image it merely sets viewing limits in the player, but you could get a lot of unused tiles generated.
16k x 8k is a small pano image for you?
John360
by John360 » Thu Jan 16, 2014 8:09 pm
16 x 8 k is small for me yes, have not used a fisheye for years, shooting 3 or more rows :)
Which resolutions does the 10.5mm give these days?
John
by mediavets » Thu Jan 16, 2014 8:11 pm
John360 wrote:16 x 8 k is small for me yes, have not used a fisheye for years, shooting 3 or more rows :)
John
Depends on the res. of the sensor. ;)
