moveto / zoomto action? (feature request)
tombred
by tombred » Sat Jan 11, 2014 11:57 pm
my original question in the bugs/discussion forum led me to a feature request:
question: is there a way to just move/zoom to a certain ath/atv/fov on a hotspot click without loading a new pano?
i'm using this frequently for pointing users to POIs on the floor or ceiling and/or to zoom in to important details in panos with higher resolutions.
up to now (if i haven't overseen something) i found only a workaround for this:
1. link to the current pano itself
2. set up a custom view with exactly the same ath/atv as the hotspot
3. set the transition to zoom in on the spot and load custom view
this is kind of fiddly and additionally it invokes an unneccesary re-loading of the current pano and if it's not exactly set up then a hickup/jump is left when re-loading the pano.
feature request: so it would be nice to have simple zoom-to-spot action available in the actions selection of a hotspot, where the loading of a new pano simply is omitted, maybe with a timing entry and/or a min zoom angle setting including a simple max checkbox.
btw: i haven't found a possibility to add/alter files in /Applications/Panotour Pro 2.0.app/Contents/Resources/transitions or somewhere else in the PTP2 systems directory for this purpose.
best
thomas
thomas bredenfeld - vienna
http://panorama-blog.com
Re: moveto / zoomto action? (feature request)
by benji33 » Mon Jan 13, 2014 8:40 am
You could add your own transitions into your user directory.
Make a copy of a transition, rename it with a new ID and update code.
See : Panotour Pro > Edit > Open user directory
But transitions are only for panorama to panorama actions.
by benji33 » Mon Jan 13, 2014 8:51 am
For zoomto, etc actions it's in our feature requests list. thanks for report
