Snow/Rain selectable to specific panorama
osmica
by osmica » Thu Nov 28, 2013 8:36 pm
Hello Kolor,
I would really like that you add a function to Snow/Rain plugins. It is now possible to apply only to the project. I can't use it anywhere...
It needs a function that will allow to select panos where a specific effect will display.
I don't need snow in the house, just in the exterior panos.
Are you working already on that?
Regards,
Toni
Re: Snow/Rain selectable to specific panorama
by Destiny » Thu Nov 28, 2013 9:24 pm
Sorry, nope.. If its snowing or raining outside, It will still rain and snow indoors too... :(
The only way out of this is to create two Tours... One for outdoors and one for indoors...
Destiny.....
osmica
by osmica » Sun Jan 12, 2014 3:36 pm
Is it possible for Kolor team to add a button in control bar: HIDE SNOW/RAIN
by benji33 » Mon Jan 13, 2014 8:36 am
A task already exists to add buttons to controls more plugins, but not for 2.0 release. into a 2.X release.
But you can modify the control bar plugin (see documentation) to update code and add image for your controls.
by Destiny » Mon Jan 13, 2014 10:08 am
You can add a combo button until this feature has more pano specific features.. ..
http://www.destinyvirtualtours.com/PTPV ... ml5=prefer
osmica
by osmica » Mon Jan 13, 2014 12:16 pm
Oh, thank you for showing me this intersting solution. Unfortunatly I don't know anything about coding and I don't know how to do that. I will need to wait Kolor Team to add this feature.
by Destiny » Mon Jan 13, 2014 3:56 pm
I can send you the code if you want it.. I would imagine it would be a while before its part of the UI.. You could add it to a button in the menu too but that would take a bit more work.. It would end up being a User Directory Template..
osmica
by osmica » Tue Jan 14, 2014 9:26 am
Destiny wrote:I can send you the code if you want it.. I would imagine it would be a while before its part of the UI.. You could add it to a button in the menu too but that would take a bit more work.. It would end up being a User Directory Template..
I apreciate your offer but I would not know where to add that code. If it is really easy and there are some instructions in the PTP documentation, I can try.
by benji33 » Tue Jan 14, 2014 10:19 am
Go to Panotour > Edit > Open user directory
Here are listed the directories to save your own actions, html templates, plugins, presets, spots and transitions.
osmica
by osmica » Tue Jan 14, 2014 11:22 am
OK, now I need from Dentiny the file(s) to save there and instructions where exactly.
by Destiny » Tue Jan 14, 2014 11:59 am
Here you will find it.. ;) viewtopic.php?f=91&t=20698&p=132543&hilit=Snow+and+Rain#p132546
I posted it up a while back...
