[SOLVED] Description of the photos   [DONE] - View the solution
StudioVR
by StudioVR » Tue Nov 26, 2013 12:02 am
I would need
- description of the photos in the gallery, not just hotspots
- Tab - Builid Protection - Time Lock on the domain
Likes: 3 posts
Liked in: 215 posts
Re: Description of the photos
by Destiny » Tue Nov 26, 2013 4:23 am
Hi... If you are talking about the actual Gallery having Description or Title text, it is not currently possible via the UI.. and... there is a bug. Not sure if its just Mac or Windows too, where you cannot even do it via the XML... It was once possible but something has occurred to make it buggy so now it does not work... Perhaps Beta 5 will have the fix....
StudioVR
by StudioVR » Tue Nov 26, 2013 10:24 am
Description would be useful
title 1
title
by mediavets » Tue Nov 26, 2013 10:27 am
StudioVR wrote:Description would be useful
Agreed. And it is promised.
Current workaround would be to add the descriptions to your images.
Likes: 3 posts
Liked in: 215 posts
by Destiny » Tue Nov 26, 2013 11:05 am
I am sure it was Beta 2 that worked via the XML. It has never worked via the UI....
Also, I am not happy with the way the image widow opens to at full size either... It never used to do that.. The Gallery is one of those features that took a while to arrive and now its going backwards....
http://www.destinyvirtualtours.com/eCar ... llery.html
Not sure what version I used here.. I think it was Beta 2... I cannot do the same with the current Beta..
Likes: 60 posts
Liked in: 169 posts
by benji33 » Thu Nov 28, 2013 10:54 am
Yes the beta5 doesn't solve this XML problem. But it's reported.
StudioVR
by StudioVR » Fri May 02, 2014 10:43 am
Thank you KOLOR for adding subtitles :)
http://www.studiovr.pl/spacery_wirtualne/Antwerp_Icons/
