feature request: keep "compass heading"
Christian Stüben
Likes: 3 posts
Liked in: 7 posts
by Christian Stüben » Fri Nov 08, 2013 10:19 am
Hi kolor people,
since nobody posted a solution to viewtopic.php?f=91&t=20380&p=130511#p130452 in the last day (uncommon for this forum), i want to make it a feature request:
when jumping inside a panotour from one pano to another by hotspot-buttons, please make a switch that can toggle between "jump to default view" and "jump to next pano and preserve compass heading".
When walking through a long chain of panos, i would like to be able to walk in either direction and have the corresponding "walk to next pano" presented immediately.
greetings from germany
Chris
Likes: 11 posts
Liked in: 94 posts
Re: feature request: keep "compass heading"
by bdd » Fri Nov 08, 2013 10:28 am
Currently you cannot do it directly with PTP, it will be added in a 2.x version.
But you can have it with a little modification in the generated code.
In 2.0 version, open the xxx_core.xml file in the xxxdata directory.
Find the "mainloadscene" action.
In this action, you will see a call to the krpano action "loadscene".
In this call, replace the "MERGE" parameter by "KEEPVIEW".
scoopz
by scoopz » Fri Nov 08, 2013 12:17 pm
Gerald thanks for the info, I'll give KEEPVIEW a try in the meantime.
Test System Spec: 15" Retina MacBook Pro, 2.7GHz i7, 16GB RAM, 768GB SSD, OS X Yosemite
Christian Stüben
Likes: 3 posts
Liked in: 7 posts
by Christian Stüben » Fri Nov 08, 2013 4:54 pm
bdd wrote:In 2.0 version, open the xxx_core.xml file in the xxxdata directory.
Bingoooooo! Thank you.
Greetings from germany
Chris
