Feature request : aspect ratio simple button
Johan
by Johan » Sun Nov 03, 2013 11:40 pm
It would be great if there was an option to set auto resize with aspect ratio kept for Logo and Simple button.
Currently you can use the % option, but then the aspect ratio is not correct.
Likes: 60 posts
Liked in: 169 posts
Re: Feature request : aspect ratio simple button
by benji33 » Mon Nov 04, 2013 10:22 am
Simply add % or pixel value for the width or height and let the other value to 0. Aspect ratio will be kept.
dmer
by dmer » Tue May 20, 2014 3:19 pm
Thank you Benjamin! Searching the forum for how to do just that - make the pop-up images show 100% vertically and maintain the aspect ratio automatically.
