Wayne Spence wrote:Good Day all,
I have 2 requests, i have had quite a few situations in the past and have a client now requesting that the Virtual tour be split into Hotel and Entertainment. What the idea is to have the Panorama Menu at the top list the Virtual Tours but have the option of adding a Menu Item that when clicked on opens a new tab with the other Virtual Tour. I know this is Possible by using the Image Zone Plugin "Logo" and using the same font you can make it look like it is part of the menu but surely this would be very helpful.
Wayne Spence wrote:The Second is a Request and in some ways i think a bug that has been overlooked. When importing cube faces it would save at least 5 minutes in each Virtual Tour workflow if Kolor could implement a line of code to automatically delete the "_0" from the Cube Faces when imported. Currently when deleting the "_0" from the Cube Face names you have to select the image delete, then check if it did delete and if not delete again. Some images take 3 or 4 tries at deleting before the "_0" is actually properly deleted.
Do you mean to create a default panorama name in which we delete the suffix ?
Wayne Spence wrote:Do you mean to create a default panorama name in which we delete the suffix ?
For example a set of cube faces would be called
Pool Area_0, Pool Area_1, Pool Area_2, Pool Area_3, Pool Area_4, Pool Area_5
Currently PTP 2 takes the name of the First Image Pool Area_0, it should be set that when importing Cube Faces the name should stay Pool Area without the "_0"
I hope this is clear enough!
