Panotour Pro 2.0 and 1.8 compatability
3dgtiger
by 3dgtiger » Fri Jul 26, 2013 8:42 pm
Will PTP 2.0 be able to open 1.8 projects?
Thanks.
-gary
by mediavets » Fri Jul 26, 2013 8:47 pm
3dgtiger wrote:Will PTP 2.0 be able to open 1.8 projects?
Thanks.
-gary
Currently only in a limited way...Only Panoramas, spots and links are loaded. The UI set in 1.8 projects is not loaded.
HansKeesom
by HansKeesom » Sun Jul 28, 2013 5:44 pm
It is absolutely not perfect at the moment.
I am working hard these days on a todo list for my own 1.8 projects to convert them to 2.0.
For the moment I think I need less then 15 minutes for each panoram to get things converted.
Now important is that I never changed anything of the code of a 1.8 project, so that problably is making it simplier.
If you also have such simple projects, I can give it a try for you. Just dropbox me the whole project.
Regards, Hans Keesom
by klausesser » Sun Jul 28, 2013 6:42 pm
mediavets wrote:Currently only in a limited way...Only Panoramas, spots and links are loaded.
Di you try to do so? I did - it didn´t work. Didn´t load a small project i made 3 weeks ago.
NOTHING loaded.
I tried "open project": no images, no spots, no links no anything loaded.
HansKeesom
by HansKeesom » Sun Jul 28, 2013 7:01 pm
Well Dropbox it to hans@alsofjeerbent.nl and I will give it a try.
by mediavets » Sun Jul 28, 2013 7:31 pm
NOTHING loaded.
Yes, just did it now; a very simple PTP1.8 project - just two spherical panos with Thumbnail stack, no hotspots, no links; had 2D navigation bar.
Didn't import the thumbnails stack -- but I didn't expect it to.
Didn't import the pano names - which is disappointing.
Didn't import navigation bar - didn't expect it to.
by mediavets » Sun Jul 28, 2013 7:33 pm
NOTHING loaded.
Perhaps you need more RAM? :D
HansKeesom
by HansKeesom » Sun Jul 28, 2013 7:39 pm
NOTHING loaded.
Tes, just did it now a very simple PTP1.8 project - just two spherical panos with Thumbnail stack, no hotspots, no links; had 2D navigation bar.
Didn't import the Thmbnails stack -- but I didn't expect it to.
Didn't import the pano names - which is disapptointing.
Yes but it can be repaired rather fast in Panotour 2.0.
I already notified kolor in the appropiate place. I want 2.0. to import a 1.8 project and immediately build an almost equill looking 2.0 tour. So a perfect import
