what about . .
what about . .
by klausesser » Fri Feb 01, 2013 5:33 pm
. . . a feature most applications already have:
when working on a bigger project containing many images it sometimes happens to fetch images from different folders.
Once imported into PanoTourPro it´s impossible to trace an image back to the folder it came from.
Could you make it possible?
Likes: 14 posts
by bdd » Mon Feb 04, 2013 9:29 am
Hello Klaus,
an issue (n°1434) is opened since a while on this subject, and it should be fixed in next Panotour release.
by klausesser » Mon Feb 04, 2013 12:11 pm
bdd wrote:Hello Klaus,
Hi Gérald!
Thanks for the information.
HansKeesom
by HansKeesom » Tue Feb 05, 2013 9:47 am
Good idea which I totally support. Once you change the name as the panorama was imported, you now have to search in notepad through the project file to find out which sourcefile it was from.
Regards, Hans Keesom
