linkable nadir path
HansKeesom
linkable nadir path
by HansKeesom » Mon Mar 28, 2011 1:25 pm
As the nadir patch is often used to display some information it would be nice if it can be linked to an url or other things like a normal hotspot
Regards, Hans Keesom
by mediavets » Mon Mar 28, 2011 2:01 pm
HansKeesom wrote:As the nadir patch is often used to display some information it would be nice if it can be linked to an url or other things like a normal hotspot
Yes, good idea.
HansKeesom
by HansKeesom » Tue May 10, 2011 9:56 pm
Solved. Place a hotspot on the ground, instead of icon, use your logo, set % for size and link it to anything you like. Easy does it. You logo will even rotate which is great when you have text on it.
