Automaticly to next panorama
by klausesser » Fri Dec 23, 2011 8:11 pm
Destiny wrote:The opportunity to edit the xml code is the true power of ptp....
Yes - i edit my xml cod all the time to get the a pano resp. a tour do whet i want. But it´s rather finetuning and didn´t ry that kind of auto-tour besides of which Arturo coded for me.
Clients very rarely ask for that. But it might hapen. We had the Ellerschloss-autotour run on an exibition for event-locations . . . and it was highly praised: nobody else had such
a nice thing . . . ;):cool:
Preferably it should run on iDevices too.
by Destiny » Sat Dec 24, 2011 12:09 am
I do not have an iPad... its on the "List"... oh hum.. to be rich.... ;(
.... but I am sure it will work on iDevices since its just an extension of the xml... the html certainly will...
This 'Auto run' feature is not for everyone true.. but in the right settings.. Real Estate windows, Exhibitions, Trade Shows etc.. Perfect!
pu2wxp
by pu2wxp » Thu Jan 12, 2012 8:44 pm
kevshu wrote:I'm using the following for this tour: http://exposedbykevin.com/index.php/360viewer/oil-barons-dream-home.html
In the Main xml file at the top.
<krpano version="1.0.8.14" logkey="false" onstart="bombtimer(0)">
    <action name="mainloadpano">
        closepanoobjects();
        closeglobalobjects();
        ifnot(stopSequence === undefined,interruptAnimation(););
        loadpano(%1,NULL,NULL,BLEND(1));
    </action>
    <events onmousedown=" set(bt,0); "/>
    <events onkeydown=" set(bt,0); "/>
    <action name="bombtimer">
       set(bt,%1);
       add(bt,1);
       delayedcall(1, bombtimer(get(bt)));
       if(bt == 60, set(bt,0); nextscene();, );
    </action>
    <action name="nextscene">
       set(bt,0);
       loadpano(get(nextpano),NULL,NULL,BLEND(1));
    </action>
In the individual pano xml files I added the set(nextpano,xml file name) line to the onxmlcompleteaction, and manually enter the next pano name.
<action name="onxmlcompleteaction">
        set(nextpano,vrt_obdh1.xml);
        firstloadcompleteaction();
</action>
There's probably a better way to use a list/array of variables in the main xml and just move through the list.
If you want to use the lookat commands, you need them in the index0+.xml files and leave the index.xml untouched. I found the lookat commands a pain, so I use a timer and auto rotation.
I hope that helps.
Really nice,
Well done, thank you!
Luciano Correa
Vista Panoramica
Campos do Jordao SP Brasil
HansKeesom
by HansKeesom » Fri Jan 13, 2012 12:46 pm
I have an iPad so if anyone of you wants me to test anything, bring it on :-)
Regards, Hans Keesom
pu2wxp
by pu2wxp » Fri Jan 13, 2012 6:38 pm
A Little trouble...
My main XML has in the first line this code:
<krpano version="1.0.8.14" logkey="false" onstart="startaction">
When the "startaction" is about the Thumbnail Stack.
So i have to change your Code for auto change panos to this first line:
<krpano version="1.0.8.14" logkey="false" onstart="startaction() ; bombtimer(0)">
    <action name="startaction">
        set(laststackthumbindex, get(stackthumb.count));
        dec(laststackthumbindex);
        buildstackthumbs(0, laststackthumbindex);
    </action>
        closepanoobjects();
    </action>
           set(bt,%1);
           add(bt,1);
        </action>
           set(bt,0);
        </action>
If not, the Thumbnails stop to working.
Best,
Luciano Correa
Vista Panoramica
Didi
by Didi » Sun Jan 29, 2012 5:11 am
`` 20 euro is nothing if it so versatile.``
+ 1 :)
Ramón
by Ramón » Mon Apr 23, 2012 9:16 pm
Autotour works, but not working radar map. Anyone know where the error
thanks.
Ramon Jimenez
bancoimagenes360
by mediavets » Mon Apr 23, 2012 10:07 pm
Ramà³n wrote:Autotour works, but not working radar map. Anyone know where the error
thanks.
Ramon Jimenez
bancoimagenes360
Which version of Panotour/Panotour pro are you using and with which operating system?
Ramón
by Ramón » Tue Apr 24, 2012 8:48 am
I'm using version V1.8.0 64 bits, Mac OS X 10.6.4
thanks
Ramà³n Jiménez
bancoimagenes360
shane999
by shane999 » Thu May 03, 2012 9:39 am
Thanks kevshu for this code. It works like a charm.
        closepanoobjects();
    </action>
       set(bt,%1);
       add(bt,1);
    </action>
       set(bt,0);
    </action>
</action>
I hope that helps.
Canon 5D Mark II - Canon 50D - Canon 8-15mm - Canon 10-22mm
Ramón
by Ramón » Thu May 03, 2012 7:56 pm
Thanks for your help
Ramon Jimenez
http://bancoimagenes360.com/
rahimhamada
by rahimhamada » Sun May 13, 2012 9:49 am
hi guys !! i did add
the
Code:
closepanoobjects();
</action>
set(bt,%1);
add(bt,1);
</action>
set(bt,0);
</action>
set(nextpano,yourfilename.xml);
</action>
but i seems to have lost the iPad/iphone usability and the radar on the map stopped showing .... any ideas ????
Previous
