[PTP 1.73 64bits Win7] Comma in Hotspot Tooltip is seen like a styling
K360
by K360 » Sun Feb 26, 2012 1:11 am
Reopened a kpt I made with an earlier version. Got a hotspot tooltip with a comma "," inside.
Compile and run locally as SWF.
When passing the mouse over the hotspot, the console appears with message "error: textstyle "XXX" not found" with XXX= text forwarding the comma in my tooltip.
Now replace the comma with anything else "-" it works...
Not a blocking one, but it seems to be a regression (was working in earlier version - couldn't say which one)
Likes: 13 posts
Liked in: 115 posts
by bdd » Mon Feb 27, 2012 8:42 am
You are true, this regression is due to a bug fix on quotes and double-quotes characters .
I'll open an issue on this bug.
But a workaround exists, since we fixed the bug on quotes :-)
Just add quotes or double-quotes at beginning and end of your tooltip.
