Hotspots : instable
zanya
Hotspots : instable
by zanya » Fri Jul 08, 2011 11:44 am
bonjour,
dès que je veux modifier un hotspot avec une video : le pano saute au précédént ? bizarre et un peu pénible ! Quelqu'un à  le même problème ?
manuel
Likes: 13 posts
Liked in: 117 posts
by bdd » Mon Jul 11, 2011 2:57 pm
this bug will be fixed in the 1.6 RC2 version of Panotour.
Regards,
zanya
by zanya » Mon Jul 11, 2011 4:49 pm
i bypassed the problems : i am using a video without sound as a link and the same video with sound as an object.
Also, you can hear a quick sound from one of the video when you open a new panorama in the same virtual tour?
i put 4 videos in one panorama and i can hear at the moment i open the panorama. The quick sound coming from one of the panorama
Audio seems to be a issue.
by mediavets » Mon Jul 11, 2011 5:55 pm
zanya wrote:i bypassed the problems : i am using a video without sound as a link and the same video with sound as an object.
That seems to be a bizarre idea - why are you doing this?
If you configure the video as the hotspot Display/Object the video will play as soon as it loads.
A video configured as a hotspot Link/Object will play when the hotspot is clicked.
Specifiying a video for the hotspot Display/Object and another video as the hotspot Link/Object just seems perverse.
And four videos in one pano scene.....have you considered how long they'll take to download?
zanya
by zanya » Mon Jul 11, 2011 7:09 pm
no strange idea : it's a video embeded in a display. SO you can see what's on the displays. It's for an multimedia exhibition
I put a video at a low resolution without audio. The videos are 20mo big max.
AND i put an object with that link, so you can see in a bigger size, what's in the video. it's very cool when it's working.
otherwise, if i let the 2 movies : i have 2 audios at the same time. I thought if the link was on, the audio of the object would be cut off.
Also, there is an audio sample that can be heard when i use the hotspots... It's another issue !
So finally, i get rid off the audio hotspots.
I wait for the next version.
by mediavets » Mon Jul 11, 2011 7:23 pm
Possible audio/sound sources:
1. Project background audio/sound
2. Pano background audio/sound
3. Audio/sound hotspots
4. Audio/sound in videos used as hostspot Link/Objects and Display/Objects
As far as I know without some custom coding - editing the XML files - all active audio sources will play simultaneously.
I don't think the next version is going to change that - do you?
by mediavets » Mon Jul 11, 2011 7:25 pm
zanya wrote:no strange idea : it's a video embeded in a display. SO you can see what's on the displays. It's for an multimedia exhibition
So this tour is for local playback only, it won't be delivered online?
In that case I guess you will 'get away' with 20Mb video files.
zanya
by zanya » Mon Jul 11, 2011 7:45 pm
you are right. I will try .flv. it's lighter
