Panotour pro et wordpress audio
zanya
by zanya » Wed Oct 06, 2010 3:26 pm
J'ai intégré mon image réalisée avec panotour pro dans une wordpress. Tout marche bien à  part les hotspots audios qui ne se lancent :
`WARNING: ExternalInterface NOT available
ERROR: soundinterface - loading of "cuvelierdata/sounds/sound1.mp3" failed
J'ai remplacé le soundinterface.swf de panotour pro par celui de krpano mais rien ne marche.
Quelqu'un a t il une solution ?
merci
Manuel
by mediavets » Wed Oct 06, 2010 3:41 pm
Audio and video files linked to a tour are never embedded.
zanya wrote:Quelqu'un a t il une solution ?
merci
Manuel
I don't think so.
Audio and video files linked within a tour are never (and cannot be) embedded.
So I believe the workaround is to make a link to a separate web page in Wordpress, rather than trying to link directly to or to embed the SWF - and choose to output an HTML file for/with your tour. Then I think that should work.
But I don't know much about Wordpress so this may not be correct either.
zanya
by zanya » Wed Oct 06, 2010 3:51 pm
Yes it works that way.
But it's much better to have a virtual tour in your photoblog as an article.
I did audio hotspots and it does not work.
by mediavets » Wed Oct 06, 2010 4:32 pm
zanya wrote:Yes it works that way.
Is this relevant?:
http://wordpress.org/extend/plugins/wp-krpano/
zanya
by zanya » Wed Oct 06, 2010 4:53 pm
i am using it already. thanks
it's a soundinterface problem.
Il y aura peut être quelqu'un de Kolor qui peut répondre ? Ca serait bien. Je suis en attente d'une solution pour présenter des portraits à  des clients.
zanya
by zanya » Mon Oct 25, 2010 6:09 pm
hi,
I managed the whole process, thanks to the patience of Vincen Pujol of www.skivr.com
It can be seen here : http://www.coworkingbordeaux.com/
bye
Manuel
vincen
Kolor Certified Trainer
Likes: 23 posts
Liked in: 4 posts
by vincen » Mon Oct 25, 2010 6:12 pm
zanya wrote:I managed the whole process, thanks to the patience of Vincen Pujol of www.skivr.com
Everything explained here ;) http://www.skivr.com/?p=739
Vince
Blog: http://www.skivr.com
zanya
by zanya » Sat Jan 15, 2011 11:14 pm
J'ai ce message après avoir intégré un pano dans un site wordpress. Quelqu'un a t il eu ce genre de prob. j'ai suivi la methode de Vincen de skivr. Mais il n'y a rien à  faire. Serait ce un prob de wordpress ?
j'ai essayé avec les mp3 de la démo : même résultat.
je suis sous Macosx snowleopard 64 bits
INFO: krpano 1.0.8.12 (build 2010-11-25)
INFO: Flashplayer MAC 10,1,102,64 PlugIn
INFO: registered to: ZETAPRESS
ERROR: soundinterface - loading of "Sdata/sounds/sound0.mp3" failed
JP31
by JP31 » Sat Jan 15, 2011 11:49 pm
Salut, pour wordpress, tu utilises le plugin qui va bien pour insérer tes visite?
Je sais que je n'ai pas installé ce plugin sur mon wordpress, mais j'arrive à  insérer une visite dedans en copiant le code html du fichier html créé par panotour dans le champ html prévu à  cet effet des nouveaux articles dans wordpress, j'ai pas encore essayé avec le son mais y a des chances que ça marche. Faut juste penser à  changer les dimensions de ta visite pour qu'elle s'adapte bien à  tes pages wordpress.
Après comme ils disent il ne faut pas insérer tous les fichiers au moment de la création de la visite sinon le fichier son risque de ne pas être exporté et comme il ne peut pas être embarqué dans le SWF, tu n'auras pas de son.
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Sun Jan 16, 2011 7:18 am
zanya wrote:ERROR: soundinterface - loading of "Sdata/sounds/sound0.mp3" failed
Cela veut dire clairement qu'il ne trouve pas le fichier MP3 (as-tu bien mis le chemin complet dans le xml ?) ou que le format du MP3 est incompatible avec le plugin Sound !
Vince
zanya
by zanya » Wed Feb 09, 2011 11:34 am
merci a vincen qui a trouvé le souci : un lien mal renseigné. Tout marche nickel.
:D
vincen
Likes: 23 posts
Liked in: 4 posts
by vincen » Wed Feb 09, 2011 11:45 am
zanya wrote:merci a vincen qui a trouvé le souci : un lien mal renseigné. Tout marche nickel.
:D
et c'est pas faute d'avoir dit de mettre les liens complets :cool::D:P
zanya
by zanya » Thu Feb 10, 2011 2:44 pm
il etait bien caché... sale petit mp3
