Cercle noir dans miniplanete-remplacement pied photo dans miniplanete
clardic
by clardic » Wed Apr 03, 2013 6:27 pm
Dans le cas d'une intro avec mini planète, je souhaite remplacer :
- le cercle noir si pas exactement 180°
ou
- le pied de l'appareil photo par une image ou autre éléments graphiques
Comment faire svp ?
Merci par avance pour votre aide
by mediavets » Wed Apr 03, 2013 10:46 pm
clardic wrote:Bonjour,
ou
Comment faire svp ?
Add a nadir patch image, the numeric value relates to scale relative to size of nadir cube face (play with it and you'll understand).
Choose an image format that supports transparency such as PNG.
clardic
by clardic » Thu Apr 04, 2013 8:33 am
Thanks for these informations.
I tried to use Nadir and jpg file. Nothing appears, probably due to the jpg, i'll try with png format.
regards
by mediavets » Thu Apr 04, 2013 10:04 am
clardic wrote:Thanks for these informations.
regards
It also works for me with a JPG - see below.
What version of Panotour/Panitour Pro are you using and with which operating system?
clardic
by clardic » Thu Apr 04, 2013 10:09 am
It's the last version of Panotour pro, bought 2 weeks ago. We are on Mac.
