Erreur plan
eric_5dmk2
Liked in: 5 posts
Erreur plan
by eric_5dmk2 » Wed Apr 03, 2013 6:49 am
WARNING: not local trusted - ExternalInterface disabled!
ERROR: looktohotspot() - hotspot "mapspot0" not found
voici le message que j'ai; ce que je ne comprends pas, c'est que tout fonctionne correctement.
Mon plan est sur le côté haut droit & lorsqu'il ouvert, il est en position centrale.
Dans les propriétés du hotspot, j'ai changé mon point pour un fichier en png.
J'ai aussi ce message:
WARNING: unknown action: closepanoobjects
Bref, à  quoi correspondent ces messages?
Pour info, je génère une visite standard & le modèle HTML est fullpage (incorporer les fichiers XML)
D'avance merci
by gkaefer » Wed Apr 03, 2013 7:33 am
the Problem causing the popup showing the Warning and the Error is the ERROR line. For this I've no solution for you. ;-(
the WARNING line "not locally trusted" displayed is about Flash security Settings for viewing the tour offline.
This you can solved ("disable") by doing following steps: http://krpano.com/docu/localusage/
if the ERROR is later solved the third line "WARNING: unknown action: closepanoobjects" will no longer affect you, it will no longer displayed (but it will be allways be displayed if you manually enable the console or any other ERROR will occur)
PS: about the ERROR: have a look here: http://www.kolor.com/forum/t17365-error-when-choosing-location-on-map
eric_5dmk2
Liked in: 5 posts
by eric_5dmk2 » Wed Apr 03, 2013 10:13 am
thanks gkaefer,
my problem came from the transition i've set up.
Was simple as that :)
Kind regards
éric
