ma première visite pour Iphone/Ipad
thierrydehove
by thierrydehove » Sat Jul 07, 2012 4:28 am
Bonsoir
je viens de monter ma première visite pour Iphone/Ipad malgré avoir la license, cette visite ne marche pas du tout
http://www.thierrydehove.com/autopano/embellie/lembellie-villa-anguilla.html
une idée ?
Merci, bonne week end, Thierry
by mediavets » Sat Jul 07, 2012 9:27 am
thierrydehove wrote:Bonsoir
une idée ?
If you select one of the HTML templates in the Tour Build options PTP will create an HTML file to launch/load the tour.
This HTML file invokes a script the detects the user-agent of the browser being used to view the tour. It will detect i-Devices and load the HTML/javascript version of the krpano Viewer and Tour rather than the Flash version.
Your Web page does not appear to incorporate/invoke this script and so it always attempts to load the Flash version of tour.
You can test the working of this script using Safrai on a desktop or laptop which has Flash installed, by switching values for the user-agent and noting whether the Flash or HTML/javascript vesions of a tour are loaded (right-click on a Windows system, cmd-click on a Mac?, will show whether or not it is the Flash version).
thierrydehove
by thierrydehove » Sat Jul 07, 2012 12:50 pm
Hi
Thanks for your reply
what do I need to do to add this code ?
Please let me know
have a super week end
Thierry
by mediavets » Sat Jul 07, 2012 2:42 pm
thierrydehove wrote:Hi
Please let me know
Thierry
Probably the easiest way to do it would be to re-build the tour with one of the HTML template options selected and then inspect the HTML file produced by PTP and take the bits that your HTML doesn't have - if you see what I mean.
Alternatively edit to the HTML file PTP creates to customise it to match you 'look-n-feel'.
You should end up in pretty much the same place.
thierrydehove
by thierrydehove » Sat Jul 07, 2012 9:07 pm
Hi
my concern is which code or script do I need to copy ?
here can I find it ?
Thanks, Thierry
