Info: active video inside the tour
Aperol
by Aperol » Wed Jan 25, 2012 9:44 pm
how is possible to display a video inside a virtualtour like this: (check the tv lcd)
virtual tour link - http://www.level8software.com/aquila_virtual/aquila_oro_eng.html
Canon 60D / Samyang 8mm fisheye / Sigma 10mm fisheye / NN3 MKII / Manfrotto Xprob055 / Autopano Giga / Panotour Pro
Liked in: 227 posts
by Destiny » Thu Jan 26, 2012 9:09 am
Hi Aperol....
What you have here is a rectangular hot spot with video playing.. In the Hotspot Properties tab you will see that you can add an Object... Firstly drawer your rectangle shape hotspot where you want it, than add your *.mp4 video Object... As you pan round the audio will fade out which is a nice feature..
Try to keep your file size down or it will take time to load.. You can stream video but not doing it this way...
firefire
by firefire » Thu Jan 26, 2012 3:30 pm
Destiny wrote:Hi Aperol....
Ah Destiny...my little font of knowledge......do you know why the video would rotate and flip (back to front) when I inserted it?! Did I miss some part of the settings?
It was an MP4 and when played normally (outside of a tour) it's absolutley fine!.
Neil.....
Liked in: 227 posts
by Destiny » Thu Jan 26, 2012 9:30 pm
Arr... well.. That might be the fact you are Left Handed... LOL... When you drawer your rectangle, you must drawer it clockwise... Start top right, then move right and then down etc.. Try that.. ;)
firefire
by firefire » Fri Jan 27, 2012 8:18 am
Destiny wrote:Arr... well.. That might be the fact you are Left Handed... LOL... When you drawer your rectangle, you must drawer it clockwise... Start top right, then move right and then down etc.. Try that.. ;)
Seriously!!....That's what I did wrong??!!!! :/:/:/ :lol: ........back to the classroom for Neil I think!! :lol:
Thanks Destiny! (again)
Neil.
