hotpsot fleche horizontale droite ou gauche
zanya
by zanya » Sun Dec 05, 2010 12:45 am
Il existe des hotspots de flèches de direction de gauche ou de droite ? c'est pratique dans une visite ? on ne fait pas que monter ?
by mediavets » Sun Dec 05, 2010 12:55 am
You can simply make your own images and then select 'other...' to use your image as the Display/Object for the hostpot.
zanya
by zanya » Sun Dec 05, 2010 6:53 pm
hello,
in fact you need to create a .png pictures, if you want to have the animation. You take the pictures of the hotspots as layers to create the .png final.
Of course, i can change the picture itself but i want to have the animation as well.
kolor could have thought of horizontal arrows ?
zanya
by zanya » Mon Dec 06, 2010 1:27 pm
bonjour,
ça marche avec le version beta 2. J'ai fait un image.png du même modèle que les spot.png. Ensuite il suffit de mettre à  jour des les fichiers .xml du pano sur lequel est le hotspot. Car il faut le rendre actif en copiant la ligne de code des autres hotspots.
Ca serait bien que cela soit plus simple à  intégre.
by mediavets » Mon Dec 06, 2010 6:53 pm
I don't really understand all of your recents posts - and they don't seem to translate well with nay of the online translators.
But....it seems to me that you are making hard work / heavy weather of this.
You didn't originally say you wanted animated custom hotspot graphics but if you do then the simplest way would be to use Flash animations (SWF format) as the Display/Object graphics for hotspots.
Alternatively you could create a custom theme following the pattern/design of the default themes.
